Component: Temp / Humidity (SHT21) (Environmental)
| Version | 2.0 |
| Category | Environmental |
Temp / Humidity component
Humidity and temperature sensor using an SHT21 IC connected via I2C. On screen GUI allows temperature and humidity values to be simulated, and will show all I2C communication in a console window.
| GetTemperatureReal | |
| Return temperature reading as a float value in degrees C | |
| [[File:]] - | Return |
| GetTemperatureData | |
| Returns the raw register pair value | |
| GetTemperatureInt | |
| Return temperature reading as an integer value in degrees C | |
| GetHumidityInt | |
| returns the relative Humidity reading as an integer value | |
| GetHumidityReal | |
| returns the Humidity reading as a float value | |
| GetHumidityData | |
| Initialises the component ready for I2C communications | |
| Sets up up the communication bus and initialises the accelerometer module. Returns 0 for success and > 0 for fail. | |
| SimSetGyro | |
| Allows the XYZ slider values to be set via the simulation | |
| [[File:]] - | X |
| [[File:]] - | Y |
| [[File:]] - | Z |
| UpdateAccelerometerData | |
| Reads from the accelerometer and updates the local XYZ variables. Returns 1 for new data and 0 for no new data | |
| SimSetCompass | |
| [[File:]] - | X |
| [[File:]] - | Y |
| [[File:]] - | Z |
| IOSetOutputPin | |
| Pin | |
| Range: 0-29 | |
| [[File:]] - | State |
| Range: 0-1 | |
| UARTReceive | |
| Channel | |
| OneWireScanBus | |
| Scans the one wire bus to detect all connected devices. Returns the number of one wire devices found. | |
| Channel | |
| SPIInitialise | |
| Channel | |
| OneWireReceiveByte | |
| Receives a byte from the one wire bus a bit at a time | |
| Channel | |
| I2CSend | |
| Channel | |
| DataOut | |
| UARTSend | |
| Channel | |
| Data | |
| OneWireGetDeviceCount | |
| Returns the number of devices found by the last ScanBus operation. | |
| Channel | |
| PWMSetPrescaler | |
| Sets the prescaler for the PWM output | |
| Channel | |
| Range: 0 - 11 | |
| Prescaler | |
| Period | |
| PWMEnable | |
| Enable a PWM output | |
| Channel | |
| Range: 0-11 | |
