| Author
Matrix TSL
| Version
1.0
| Category
Analog Input
Joystick (Sparkfun Quiic) component
An XY sprung joystick with click switch allowing for easy user input control. Connected using I2C bus.
Traffic Light Scenario
ChangeI2CAddress
| Allows the I2C Device address to be changed which in turn allows more then one RFID reader to sit on the same physical I2C bus. Returns 1 if succesful.
- BYTE
NewAddress
| Range: 8 to 119 or 0x08 - 0x77
| [[File:]] -
CheckButton
| Checks to see if the button has been pressed since the last read of CheckButton or ReadButton.
| [[File:]] -
ReadAxis
| Reads a single axis of the joystick and returns as a signed integer value.
- BYTE
Axis
| Range 0-1 Where 0=X, 1=Y
| [[File:]] -
Type
| 0 = Signed (-512 to 511), 1 = Unsigned (0 to 1023)
| [[File:]] -
ReadButton
| Checks to see if the button is currently pressed
| [[File:]] -
| Initialises the I2C bus ready for communications with the module.
OpenPort
| Opens the currently selected COM port, allowing data to be sent and received.
SetProp
| Allows the COM port property to be set from a parent component.
- STRING
PropName
- ULONG
PropVal
GetProp
| Allows the property filter for the COM port list to be copied to a parent component.
- STRING
PropName
- STRING
GetConsoleHandle
| Gets the handle to the console allowing data displaying on the panel etc.
| [[File:]] -
SendByteArray
| Sends an array of bytes to the COM port.
- BYTE
Data
| Data byte array to send
- UINT
Length
| Number of bytes to send
ReceiveBinary16Bit
| Receives a binary 16-bit value split across two bytes.
| [[File:]] -
MSBfirst
| 0=Least significant byte first, 1=Most significant byte first
- BYTE
Timeout
| Max amount of time in ms to wait between bytes
- UINT
ReceiveFloat
| Attempts to receive a floating point number as ASCII characters and convert back into a numeric value. Note this function will receive until a timeout or a none numeric char is received, the none numeric char will be lost.
- BYTE
Timeout
| Max time in ms to wait in between bytes
| [[File:]] -
IgnoreData
| 0=Dont ignore any data, 1=Ignore any initial none numeric data
| [[File:]] -
SendFloat
| Sends out a floating point number as an ASCII String from the UART interface.
| [[File:]] -
Number
SendHexNumber
| Sends out a number as an ASCII hexadecimal String from the UART interface.
- ULONG
Number
- BYTE
NumChars
| Number of characters in the string data, 0 for auto, 2 for 0x00, 4 for 0x0000
| [[File:]] -
Prefix
| Generate hexadecimal prefix 0x e.g. 1= 0xFF, 0= FF
SetFlowControl
| Allows the Flowcontrol signals to be enabled or disabled.
- BYTE
State
| A value of 0 disables flow control, 1 or above willl enable flow control.
OpenPort
ReceiveHexNumber
| Attempts to receive a hex number as ASCII characters and convert back into a numeric value. Note this function will receive until a timeout or a none hexadecimal char is received, the none numeric char will be lost.
- BYTE
Timeout
| [[File:]] -
IgnoreData
| [[File:]] -
Prefix
| Look for prefix before receiving, 1=0xFF, 0=FF
- ULONG
SetProp
- STRING
PropName
- ULONG
PropVal
SendBinary32Bit
| Sends out a 32-bit binary value split across four bytes.
- ULONG
Value
| [[File:]] -
MSBfirst
SendBinaryFloat
| Sends out a 32-bit binary floating point value split across four bytes.
| [[File:]] -
Value
| [[File:]] -
MSBfirst
GetProp
- STRING
PropName
- STRING
ReceiveByteArray
| Attempts to receive an array of bytes using the COM port Returns the number of bytes received.
- BYTE
Data
- UINT
MaxLength
| Max number of bytes to try and read
- UINT
Timeout
| Time to wait for incoming data in milliseconds
- UINT
ReceiveString
| Attempts to receive an string using the COM port Returns the number of bytes received.
- UINT
Timeout
- UINT
MaxLength
- STRING
PWMEnable
| Allows pulse width modulated transistor outputs to be switched on or off. Bit 0 = Enable AB Bit 1 = A / Bit 2 = B Bit 3 = C / Bit 4 = D Bit 5 = Enable CD
- BYTE
EnableMask
| Range 0-63 or 0b00000 to 0b111111
GetProp
- STRING
PropName
- STRING
Return To Center
| Decides if the joystick automatically returns to the center position when released. Yes: The joystick will return to the center when released. No: The joystick will remain in the current position when released.
X Min
X Max
Y Min
Y Max
Device Address
| External device address used to communicate with the module. Default 32 or 0x20
| Channel selection
Baud Select
| Baud rate option selector
| Baud rate to be used
SDA
SCL
Stop Delay
Simulations
Simulate Comms
| Controls if we are using the panel simulation or simulating the I2C calls for use with an I2C injector.
| Selects if the component pin connections are automatically generated on the data recorder window or not. Yes: Automatically add the component pins to a group on the data recorder which will reflect the sim data during simultion. No: Do not show the pin signals on the data recorder window.
API
| Specifies the injector component on the panel to interact with to provide comms simulation.
