| Author
Matrix Ltd
| Version
1.2
| Category
Indicators
Speech (RealSpeak) component
Advanced speech engine allowing realistic text to speech in multiple languages using the RealSpeak voice engine. Available in simulation only.
Speak
| Simulation only call to allow the computer to speak using the RealSpeak voice engine. Languages need to be downloaded and installed then selected using the Voice property.
- STRING
DataString
GetTag
| Gets the tag ID returned as a byte array. Must be called after CheckForTag has returned true. Byte array variable should be at least 6 bytes long.
- BYTE
Data
IsKnownID
| Checks to see if the last tag read by CheckForTag is saved into memory. Returns true if tag is stored in memory.
| [[File:]] -
| Initialises the I2C bus ready for communications with the module. Wipes the tag ID storage ready for data to be stored.
OpenPort
| Opens the currently selected COM port, allowing data to be sent and received.
SetProp
| Allows the COM port property to be set from a parent component.
- STRING
PropName
- ULONG
PropVal
GetProp
| Allows the property filter for the COM port list to be copied to a parent component.
- STRING
PropName
- STRING
GetConsoleHandle
| Gets the handle to the console allowing data displaying on the panel etc.
| [[File:]] -
SendByteArray
| Sends an array of bytes to the COM port.
- BYTE
Data
| Data byte array to send
- UINT
Length
| Number of bytes to send
ReceiveBinary16Bit
| Receives a binary 16-bit value split across two bytes.
| [[File:]] -
MSBfirst
| 0=Least significant byte first, 1=Most significant byte first
- BYTE
Timeout
| Max amount of time in ms to wait between bytes
- UINT
ReceiveFloat
| Attempts to receive a floating point number as ASCII characters and convert back into a numeric value. Note this function will receive until a timeout or a none numeric char is received, the none numeric char will be lost.
- BYTE
Timeout
| Max time in ms to wait in between bytes
| [[File:]] -
IgnoreData
| 0=Dont ignore any data, 1=Ignore any initial none numeric data
| [[File:]] -
SendFloat
| Sends out a floating point number as an ASCII String from the UART interface.
| [[File:]] -
Number
SendHexNumber
| Sends out a number as an ASCII hexadecimal String from the UART interface.
- ULONG
Number
- BYTE
NumChars
| Number of characters in the string data, 0 for auto, 2 for 0x00, 4 for 0x0000
| [[File:]] -
Prefix
| Generate hexadecimal prefix 0x e.g. 1= 0xFF, 0= FF
SetFlowControl
| Allows the Flowcontrol signals to be enabled or disabled.
- BYTE
State
| A value of 0 disables flow control, 1 or above willl enable flow control.
OpenPort
ReceiveHexNumber
| Attempts to receive a hex number as ASCII characters and convert back into a numeric value. Note this function will receive until a timeout or a none hexadecimal char is received, the none numeric char will be lost.
- BYTE
Timeout
| [[File:]] -
IgnoreData
| [[File:]] -
Prefix
| Look for prefix before receiving, 1=0xFF, 0=FF
- ULONG
SetProp
- STRING
PropName
- ULONG
PropVal
SendBinary32Bit
| Sends out a 32-bit binary value split across four bytes.
- ULONG
Value
| [[File:]] -
MSBfirst
SendBinaryFloat
| Sends out a 32-bit binary floating point value split across four bytes.
| [[File:]] -
Value
| [[File:]] -
MSBfirst
GetProp
- STRING
PropName
- STRING
ReceiveByteArray
| Attempts to receive an array of bytes using the COM port Returns the number of bytes received.
- BYTE
Data
- UINT
MaxLength
| Max number of bytes to try and read
- UINT
Timeout
| Time to wait for incoming data in milliseconds
- UINT
ReceiveString
| Attempts to receive an string using the COM port Returns the number of bytes received.
- UINT
Timeout
- UINT
MaxLength
- STRING
PWMEnable
| Allows pulse width modulated transistor outputs to be switched on or off. Bit 0 = Enable AB Bit 1 = A / Bit 2 = B Bit 3 = C / Bit 4 = D Bit 5 = Enable CD
- BYTE
EnableMask
| Range 0-63 or 0b00000 to 0b111111
GetProp
- STRING
PropName
- STRING
Voice
| RealSpeak selected voice - Download and install RealSpeak voices for more options.
Rate
| Voice speech rate - Default 1 - Range (0-100)
Simulations
