Component: ADC QUAD + DAC (PCF8591) (Analog Input)
Revision as of 10:41, 17 November 2021 by Wiki bot (talk | contribs)
Category Analog Input
ADC QUAD + DAC (PCF8591) component
An I2C device allowing for up to 4 x 8-bit analogue inputs as well as 1 x 8-bit analogue output. Up to 8 devices can be used together ona signel I2C bus.
EnableDAC
Enables and Disables the DAC output, Default Disabled.
[[File:]] - Enabled
0=Disabled, 1=Enabled
WriteDAC
Writes a value to the digital to analogue output.
- BYTE Value
SetupADC
Configures how the ADC inputs are wired
- BYTE Configuration
Range: 0-3, Default 0
SampleADC
Performs a single ADC sample on the selected ADC channel
- BYTE Channel
Range: 0-3
Sets up the I2C bus ready for communications with the device.
Confgures the SPI bus ready for communications and initialises the MCP356X device. Returns true if device is responding to commands.
[[File:]] - Return
SendChar
Transmits a byte value to the Zigbee module.
- BYTE Byte
Data byte to transmit. Range 0-255
InitNetwork
Initialises the Zigbee module and attempts to setup or join the network
ConnectToCoordinator
Attempts to connect the data channel to the network coordinator node.
MIAC_Module_GetData
- BYTE Index
ConnectToName
Attempts to connect the data channel to a named device on the network.
- STRING Name
StoreParams
Stores the current register set into the Zigbee module's non volatile memory
EnterCommandMode
Moves from data mode into command mode by sending the special characters
RestartNetwork
Attempts to restart the network
MIAC_Module_Message
- UINT CAN_ID
- UINT CMD_ID
ConnectToAll
Attempts to connect the data channel to all devices on the network.
ConnectFromLibrary
Attempts to connect the data channel to a known device on the network.
- BYTE Mode
- BYTE Device
ConnectToAddress
Attempts to connect the data channel to a specific device address on the network.
- STRING Address
GetSignalLevel
Returns the signal strength of the last signal received
ExitCommandMode
Returns from command mode to allow data to be sent and received
MIAC_Module_PushData
- BYTE Data
ReadAddressFromBuffer
Reads a byte from a 16-bit Zigbee device address
- BYTE Device
- BYTE Idx
SendATCommand
Transmits a string of values to the Zigbee module.
- STRING Command
Transmits a command to the Zigbee module followed by a carriage return
ScanNetwork
Scans the local network for devices and stores into a local device array. Mode = 0 store device names, mode = 1 store device addresses. Returns the number of devices found.
- BYTE Mode
GetATResponse
Waits for a response from the Zigbee module. If the Logging parameter is set then the response is stored in memory allowing the software to read the reply.
- BYTE Logging
ReceiveChar
Attempt to receive a byte from the Zigbee module.
- BYTE nTimeout
MODPMSHAPE
Sets PM waveform shape to; 0 = SINE, 1 = SQUARE, 2 = RAMPUP, 3 = RAMPDN, 4 = TRIANG, 5 = NOISE, 6 = DC, 7 = SINC, 8 = EXPRISE, 9 = LOGRISE, 10 = ARB1, 11 = ARB2, 12 = ARB3, 13= ARB4.
- BYTE Shape
Sets PM waveform shape (1 = SINE, 2 = SQUARE, 3 = RAMPUP, 4 = RAMPDN, 5 = TRIANG, 6 = NOISE, 7 = DC, 8 = SINC, 9 = EXPRISE, 10 = LOGRISE, 11 = ARB1, 12 = ARB2, 13 = ARB3, 14= ARB4).
ARB4
Loads the binary-data to an existing arbitrary waveform memory location ARB4.
- BYTE Waveform
CLKSRRet
Returns the clock source <INT> or <EXT>.
[[File:]] - Return
MODPMDEV
Sets PM waveform deviation to <nrf> degrees. (Lower limit: -360° - Upper limit: 360°).
[[File:]] - Degrees
Sets PM waveform deviation in degrees (-360 - 360).
MSTLOCK
Sends signal to SLAVE generator to get synchronised
HILVL
Sets the amplitude-high-level to <nrf> Volts. (Lower limit: -0.490 V - Upper limit: 5.000 V).
[[File:]] - HighLevel
Sets the amplitude-high-level in Volts(V) (-0.490 V - 5.000 V).
ARB3
Loads the binary-data to an existing arbitrary waveform memory location ARB3.
- UINT Waveform
WAVE
Sets the waveform type. 0 = SINE, 1 = SQUARE, 2 = RAMP, 3 = TRIANG, 4 = PULSE, 5 = NOISE, 6 = ARB
- BYTE WaveType
0 = SINE, 1 = SQUARE, 2 = RAMP, 3 = TRIANG, 4 = PULSE, 5 = NOISE, 6 = ARB.
CALADJ
Adjust the selected calibration value by <nrf> (Lower limit: -100 - Upper limit: 100).
[[File:]] - Calibrate
Adjust the selected calibration value (-100 - 100).
STBRet
Returns the value of the Status Byte Register in <nr1> numeric format.
ARB2
Loads the binary-data to an existing arbitrary waveform memory location ARB2.
- UINT Waveform
EERRet
Query and clear execution error number register.
- STRING Return
MODFMSRC
Sets FM waveform source to; 0 INT, 1 = EXT.
[[File:]] - Source
Sets FM waveform source (0 = INT, 1 = EXT).
MODAMFREQ
Sets AM waveform frequency to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 20kHz).
[[File:]] - Frequency
Sets AM waveform frequency in Hertz(Hz) (1uHz - 20kHz).
ESE
Sets the Standard Event Status Enable Register to the value of <nrf>.
- BYTE Value
Value of register 0-255
ARB1
Loads the binary-data to an existing arbitrary waveform memory location ARB1.
- UINT Waveform
16 Bit binary number for arbitrary waveform.
ARB4DEFRet
Returns user specified waveform name, waveform pint interpolation state and waveform length of ARB4.
- STRING Return
CLS
Clears status byte register of the interface.
MSTRELOCK
Resynchronises the two generators in MASTER-SLAVE mode.
NOISLVL
Sets the output noise level to <nr1> %. (Lower limit: 0% - Upper limit: 50%)
- BYTE Percent
Sets the output noise level in percent. (0 - 50)
LOCKMODE
Sets the synchronising mode to; 0 = MASTER, 1 = SLAVE, 2 = INDEP.
- BYTE Mode
Sets the synchronising mode (0 = MASTER, 1 = SLAVE, 2 = INDEP).
ADDRESSRet
Returns the instruments address
[[File:]] - Return
MODPMSRC
Sets PM waveform source to; 0 INT, 1 = EXT.
[[File:]] - Source
Sets PM waveform source (0 = INT, 1 = EXT).
MODPWMSRC
Sets PWM waveform source to; 0 = INT, 1 = EXT.
[[File:]] - Source
Sets PWM waveform source (0 = INT, 1 = EXT).
MOD
Sets modulation to; 0 = OFF, 1 = AM, 2 = FM, 3 = PM, 4 = FSK, 5 = PWM.
- BYTE Modulation
Sets modulation (0 = OFF, 1 = AM, 2 = FM, 3 = PM, 4 = FSK, 5 = PWM).
ISTRet
Returns IST local message as defined by IEEE Std. 488.2. The syntax of the response is 0<rmt>, if the local message is false, or 1<rmt>, if the local message is true.
[[File:]] - Return
LRNRet
Returns the complete setup of the instrument as a binary data block
[[File:]] - Return
OPCRet
Query Operation Complete status. The response is always 1<rmt> and will be available immediately the command is executed because all commands are sequential.
[[File:]] - Return
SWPTYPE
Sets the sweep type to; 0 = LINUP, 1 = LINDN, 2 = LINUPDN, 3 = LINDNUP, 4 = LOGUP, 5 = LOGDN, 6 = LOGUPDN, 7 = LOGDNUP.
- BYTE Type
Set the sweep type (0 = LINUP, 1 = LINDN, 2 = LINUPDN, 3 = LINDNUP, 4 = LOGUP, 5 = LOGDN, 6 = LOGUPDN, 7 = LOGDNUP).
PULSRANGE
Sets PWM waveform source to <1>, <2> or <3>; 1 = 1, 2 = 2, 3 = 3.
- BYTE Range
Sets the pulse rise and fall range. (1, 2 or 3)
TSTRet
The generator has no self test capability and the response is always 0 <rmt>.
[[File:]] - Return
BSTTRGPOL
Sets the burst trigger slope to; 0 = POS, 1 = NEG.
[[File:]] - Slope
Set the burst trigger slope (0 = POS, 1 = NEG).
ARB3Ret
Returns the binary-data from an existing abbitrary wavefrom memory location.
BSTPHASE
Sets the burst phase to <nrf> degrees. (Lower limit: -360 - Upper limit: 360)
[[File:]] - Degrees
Sets the burst phase in degrees (-360 - 360)
IDNRet
Returns the instrument identification. The IDN is saved to the variable passed from the function 'ReturnIDN'. The return parameter is TRUE when the IDN is successfully returned.
- STRING ReturnIDN
- STRING Return
SWPTRGPER
Sets the sweep trigger period to <nrf> seconds
[[File:]] - Seconds
Set the sweep trigger period in seconds.
PULSDLY
Sets the waveform delay to <nrf> sec
[[File:]] - Sec
Opens the COM port ready for communications.
API
Device Address
The address pins are used to allow up to 8 individual devices to be connected onto an I2C bus. Sets the state of the pins.
Channel selection
SDA
SCL
Stop Delay
Baud Select
Baud rate to be used
Simulations
Simulate Comms
Allows the communications to be simulated overriding the value on the panel slider controls.
