Component: FTDI (FT800) (FT800) (Misc)
Revision as of 11:03, 17 November 2021 by Wiki bot (talk | contribs)
Author MatrixTSL
Version 2.0
Category Misc
FTDI (FT800) component
The FT800 provides a powerful feature set in a small package to create dynamic HMI interfaces. The device supports line by line graphics rendering to 1/16 of a pixel on displays with resolution up to 512 x 512 with 262K colours. The chip includes a touch controller for sensing touch feedback from a TFT display with a resistive touch panel as well as a sound synthesizer and audio playback with a PWM output to drive a speaker.
Fc9-comp-macro.png IncrementCommandOffset
Adds commandSize to the currentOffset. Checks for 4K ring-buffer offset roll-over
Fc9-u16-icon.png - UINT currentOffset
graphics processor command list pointer
Fc9-u8-icon.png - BYTE commandSize
number of bytes to increment the offset
Fc9-comp-macro.png MemRead16
Reads a single unsigned int from the FT800 internal address space
Fc9-u32-icon.png - ULONG Address
Fc9-comp-macro.png MemRead8
Reads a single data byte from the FT800 internal address space
Fc9-comp-macro.png MemRead32
Reads a single unsigned long from the FT800 internal address space
Fc9-u32-icon.png - ULONG Return
Fc9-comp-macro.png MemWrite16
Writes a unsigned int value to the FT800 internal address space
Fc9-u16-icon.png - UINT Data
Fc9-comp-macro.png MemWrite8
Writes a byte value to the FT800 internal address space
Fc9-u8-icon.png - BYTE Data
Fc9-comp-macro.png CommandWrite
Sends FT800 command
Fc9-u8-icon.png - BYTE Command
Fc9-comp-macro.png MemWrite32
Writes a unsigned long value to the FT800 internal address space
Fc9-u32-icon.png - ULONG Data
Fc9-comp-macro.png Initialise
System initialization routines. Executed once on reset. Returns 0 if device not detected or 1 if device is correctly initialised.
Fc9-type-16-icon.png Channel
SPI Channel selector
Fc9-type-16-icon.png Prescale
Prescale option selector
Fc9-type-5-icon.png MOSI
Fc9-type-5-icon.png MISO
Fc9-type-5-icon.png CLK
Fc9-type-5-icon.png Power Pin
Fc9-type-5-icon.png CS Pin
Fc9-type-21-icon.png Width
Active width of LCD display
Fc9-type-21-icon.png Height
Active height of LCD display
Fc9-type-21-icon.png HCycle
Total number of clocks per line
Fc9-type-21-icon.png HOffset
Start of active line
Fc9-type-21-icon.png HSync0
Start of horizontal sync pulse
Fc9-type-21-icon.png HSync1
End of horizontal sync pulse
Fc9-type-21-icon.png VCycle
Total number of lines per screen
Fc9-type-21-icon.png VOffset
Start of active screen
Fc9-type-21-icon.png VSync0
Start of vertical sync pulse
Fc9-type-21-icon.png VSync1
End of vertical sync pulse
Fc9-type-21-icon.png PixelClock
Pixel Clock
Fc9-type-21-icon.png Swizzle
Define RGB output pins
Fc9-type-21-icon.png Clock Polarity
Define active edge of PCLK
Fc9-conn-icon.png Simulations
Fc9-type-16-icon.png API
