Component: Ultrasonic Ranger (Grove 101020010) (101020010) (Audio)
Jump to navigationJump to search| Author | Matrix Ltd |
| Category | Audio |
Ultrasonic Ranger (Grove 101020010) component
The ultrasonic sensor is a non-contact distance measurement module. It's designed for easy modular project usage with industrial performance. Detecting range: 3cm to 4m, best in 30 degree angle.
This example performs an ultrasonic range sample and then converts the sample from a timing into a measurement in millimetres.
| WaitForEcho | |
| Waits until the echo has been received from the Ping macro allowing you to perform your own timing. | |
| Ping | |
| Performs a transmit ping allowing you to monitor the incoming signal and perform your own timings maybe using a rising edge interrupt and a timer. | |
