Component: Modbus Slave (SCADA) (Comms: System)
Revision as of 11:05, 17 November 2021 by Wiki bot (talk | contribs)
Category Comms: System
Modbus Slave (SCADA) component
Modbus component for creating Modbus compatible slave hardware via RS232 or RS485.
ReadHoldingRegister
Reads the value of a single holding register.
- UINT Address
Coil Address
SetCoil
Sets the state of a single digital coil.
- UINT Address
Coil Address
- BYTE State
0=off, 1=on
SetDigitalInput
Sets the state of a single digital input.
- UINT Address
Coil Address
- BYTE State
0=off, 1=on
SetSlaveAddress
Allows the slave address to be overridden from the default slave address specified in the component property. The number of bytes used for the address is fixed by the Slave ID Bytes property to save on RAM usage.
- UINT SlaveAddress
ChangeFrameType
Default frame type is the type set in the component properties.
- BYTE Type
0 = Modbus RTU / 1 = Modbus ASCII
ReadCoils
Reads the state of up to eight digital coils. Can pack a max of 8-bits together in a single operation
- UINT StartAddress
Coil Address Range 0 to (NumCoils - 1)
- BYTE AddressCount
Range 1-8
SetHoldingRegister
Sets the state of a single holding register.
- UINT Address
Coil Address
- UINT Value
Analogue Value range 0 - 65535
ReadAnalogInput
Reads the value of a single analogue input.
- UINT Address
Coil Address
CheckForIncoming
Checks for an incoming message and if the data address is within range then also automatically replies with the correct reply. Returns 0 if no comms received, 1 for a succesful transaction, 255 for an error.
ReadDigitalInputs
Reads the state of up to eight digital inputs. Can pack a max of 8-bits together in a single operation
- UINT StartAddress
- BYTE AddressCount
Range 1-8
GetLastIncoming
Gets a value from the last incoming command. Index 0 = 0 Read / 1 Write Index 1 = 0 Coils / 1 DigInput / 2 AnInput / 3 Register Index 2 = Address Index 3 = Number
SetAnalogInput
Sets the state of a single analogue input.
- UINT Address
Coil Address
- UINT Value
Starts up the UART to allow communications and initialises the states of the various Modbus Coils, Inputs and Registers to 0.
Frame Type
Switches between RTU and ASCII forms of Modbus
Receive Buffer Size
Receive Timeout
Length in milliseconds to wait for additional bytes to be received when checking for incoming messages.
Slave ID Bytes
Slave Address
Reply Delay
Delay in micro seconds to wait before transmitting a reply
Maintain Stats
Controls if the last command from the master is logged allowing for easier value updates. No - Do not log commands Yes - Commands are logged and available via the GetLastIncoming macro
Console Columns
Data Source
COM Port
Lists all the current available COM port hardware on your PC.
Refresh Ports
COM port data rate in bits per second
Starting Address
Start address of the Modbus coils. Referenced from 0. For example Slave 1 might have 100 coils addressed 0-99 Start Address = 0 Slave 2 might have 100 coils addressed 100-199 Start Address = 100
Number of Addresses
Specifies how many Coils are available on the slave. Each address consumes a single bit of RAM, 8 Addresses are packed together into a single RAM Byte.
Starting Address
Start address of the Modbus digital inputs. Referenced from 0. For example Slave 1 might have 100 inputs addressed 0-99 Start Address = 0 Slave 2 might have 100 inputs addressed 100-199 Start Address = 100
Number of Addresses
Specifies how many Digital Inputs are available on the slave. Each address consumes a single bit of RAM, 8 Addresses are packed together into a single RAM Byte.
Starting Address
Start address of the Modbus analogue inputs. Referenced from 0. For example Slave 1 might have 100 inputs addressed 0-99 Start Address = 0 Slave 2 might have 100 inputs addressed 100-199 Start Address = 100
Number of Addresses
Specifies how many 16-bit analogue inputs are available on the slave. Each address consumes two RAM Bytes.
Starting Address
Start address of the Modbus registers. Referenced from 0. For example Slave 1 might have 100 registers addressed 0-99 Start Address = 0 Slave 2 might have 100 registers addressed 100-199 Start Address = 100
Number of Addresses
Specifies how many 16-bit holding registers are available on the slave. Each address consumes two RAM Bytes.
Simulations
