Component: Simulation External Input (Runtime Tools)
| Version | 1.1 |
| Category | Runtime Tools |
Simulation External Input component
A simulation only component designed to allow a single digital pin to be toggled at a set frequency. Allows things like switch presses or external square waves to be used with the simulation.
| Control_Pulse | |
| Controls if the toggle input is enabled or disabled allowing you to stop and start the waveform. | |
| State | |
| 0=Disabled, 1=Enabled | |
| Get_Pulse_Count | |
| Reads the number of pulses remaining in the current run. The Pulse Count property needs to have an initial value > 0 to switch on the pulse counting mode. | |
| Set_Space | |
| Overrides the component property setting allowing for a variable frequency input or adjustable Space timings. | |
| Delay | |
| Delay between transitiions in milliseconds. | |
| Set_Frequency | |
| Allows the frequency to be changed on the fly | |
| [[File:]] - | Frequency |
| Set_Mark | |
| Overrides the component property setting allowing for a variable frequency input or adjustable Mark timings. | |
| Delay | |
