Component: USB MIDI (Comms: USB)
Revision as of 11:08, 17 November 2021 by Wiki bot (talk | contribs)
Author Matrix Ltd.
Version 1.3
Category Comms: USB
USB MIDI component
Component to create and communicate using a standard MIDI connection. Compatible with simulation and USB enabled microcontroller devices. Currently only compatible with the 16-bit PIC range of devices.
SendMIDI
Sends a MIDI packet consisting of up to three bytes of information,
- BYTE Status
MIDI Status Byte - Used for commands such as NoteOn, NoteOff etc.
- BYTE Data1
MIDI Data Byte - Used as a parameter specific to the specified command
- BYTE Data2
SendPitchChange
Sends out a pitch change command on the specified channel.
- BYTE Channel
Channel to send the pitch change to
- UINT Pitch_Change
New pitch value to use, Default 0x2000
SendNoteOff
Sends a note off command using the channel, note and velocity specified.
- BYTE Channel
- BYTE Note
- BYTE Velocity
SendControl
Sends a control command using the channel, controller and value specified.
- BYTE Channel
- BYTE Controller
- BYTE Value
SendNoteOn
Sends a note on command using the channel, note and velocity specified.
- BYTE Channel
- BYTE Note
- BYTE Velocity
ReceiveMIDI
Waits for the time specified in the timeout parameter for an incoming MIDI message. Returns 0 to indicate a timeout, otherwise returns the first value from the MIDI message.
- BYTE Timeout
SendPolyPressure
Sends a note press with an associated polyphonic pressure value.
- BYTE Channel
- BYTE Note
- BYTE Pressure
ReadData
Reads a byte from the last received MIDI message
- BYTE Idx
Byte to read 0-3
SendPatch
- BYTE Channel
- BYTE Instrument
SendChannelPressure
- BYTE Channel
- BYTE Pressure
Starts up the USB communications and attempts to enumerate. Returns 0 for a successful startup or 255 for a enumeration timeout.
Vendor ID
USB VID
Product ID
USB PID
Device Name
USB Device Name
Manufacturer
USB Manufacturer
Major Version
USB Major Version Number
Minor Version
USB Minor Version Number
Enumeration Timeout
Specifies if the enumeration (Initialise function) can timeout if taking too long.
Simulations
Text displayed on the I/O flasher comms component.
Data Source
Simulation data source used to allow the component to connect to specific MIDI hardware or the the data injector components.
MIDI Port
