Component: GLCD (KS0108) (Graphical Monochrome)
Revision as of 11:09, 17 November 2021 by Wiki bot (talk | contribs)
Version 1.4
Category Graphical Monochrome
GLCD (KS0108) component
Graphical display component designed to work with the KS0108 type monochrome displays. Also compatible with the newer S6A0107 controller IC displays.
ReadFontWidth
- BYTE Font
- BYTE Character
SetFontScaler
- BYTE ScaleX
- BYTE ScaleY
[[File:]] - Number
- UINT X
- UINT Y
- BYTE Font
- BYTE Transparent
DrawLine
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
DrawEllipse
- UINT X
- UINT Y
- UINT XRadius
- UINT YRadius
- BYTE Transparent
- BYTE Solid
Plot
- UINT X1
- UINT Y1
SetDisplayOrientation
- BYTE Orientation
BPlot
- UINT X1
- UINT Y1
ReadFontStat
- BYTE Font
- BYTE Index
0=SpaceWidth, 1=PixelHeight
Print
- STRING Str
- UINT X1
- UINT Y1
- BYTE Font
- BYTE Transparent
ClearDisplay
SetBackgroundColour
- BYTE Pixel_Colour
0=White, 1=Black
DrawCircle
- UINT X
- UINT Y
- UINT Radius
- BYTE Transparent
- BYTE Solid
SetForegroundColour
- BYTE Pixel_Colour
0=White, 1=Black
DrawRectangle
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
- BYTE Transparent
- BYTE Solid
Pixel Width
Pixel Height
Controller Count
Speicifies the number of controller IC's built into the display and therefore the number of available chip select pins
Monochrome
Foreground Color
Background Colour
Color Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
Font Count
Font
Character Spacing
Space Width
Font
Character Spacing
Space Width
Font
Character Spacing
Space Width
Font
Character Spacing
Space Width
Display Method
Enable Delay
Time in micro seconds to wait before and after toggling the enable pin.
CS1
Chip select to address the first controller IC
CS2
Chip select to address the second controller IC
RS
Data / Instruction register select pin.
RW
Read / write select pin
Enable
Data enable to clock a command or data in or out of the device
Data0
Data Pin 0
Data1
Data Pin 1
Data2
Data Pin 2
Data3
Data Pin 3
Data4
Data Pin 4
Data5
Data Pin 5
Data6
Data Pin 6
Data7
Data Pin 7
Reset
Display reset pin
Simulations
