Component: MIAC USB Slave API (PIC) (AllCode)
Revision as of 13:29, 17 November 2021 by Wiki bot (talk | contribs)
Version 1.1
Category AllCode
MIAC USB Slave API (PIC) component
Allows Matrix's MIAC PLC to be used as a PC peripheral controlled by Flowcode via a USB connection. Requires that the MIAC (PIC) has the USB Slave firmware downloaded to it.
Firmware & USB Driver
The MIAC needs programming with the USB Slave firmware to function correctly with the MIAC USB Slave component.
Use the MIACprog tool to download the firmware .hex file to the MIAC.
File:MIAC USB Slave Firmware.zip
The MIAC USB Slave USB driver will need to be installed before Windows will correctly recognise the device and allow Flowcode to communicate correctly.
Controlled Using Flowcode
Here is a simple Flowcode program to toggle one of the transistor outputs on the MIAC USB Slave device. Remember to connect a linking wire between the (M) screw terminal to the (V+) screw terminal to allow the Transistor LEDs to light. FC6 Icon.png MIAC USB Slave Here is an example of the high level MIAC USB Slave console.
Here is an example of the low level MIAC USB Slave console.
If the MIAC USB Slave component can see the MIAC USB Slave then you will able to select the instance via the Instance property.
Multiple MIAC USB slaves can be connected to a single PC and controlled by adding multiple MIAC USB Slave components each referring to their own instance of the hardware.
Controlled Using VB6 / VB2008
Files taken from the Locktronics Industrial sensor, actuator and control applications solution
File:VB Examples.zip
Controlled Using Labview
File:Labview Examples.zip
Command Table
Command Number Description Parameters Returns
1 Digital Input Channel (1-8) Input State (0-1)
2 Digital Multi Input N/A Input State 8-bit (0-255)
3 Analogue Input Channel (1-8) Input ADC Reading (0-255)
4 Read Keypad Buffer N/A Key Press (0-8 or 255)
5 Clear Keypad Buffer N/A N/A
6 Relay Control Channel (1-4)
Relay State (0-1)
N/A
7 Transistor Control Channel (1-4)
Transistor State (0-1)
N/A
8 Multi Output Control Output Value (0-255)
Output Mask (0-255)
N/A
9 Display Clear N/A N/A
10 Display Cursor Position X Coord (0-15)
Y Coord (0-3)
N/A
11 Display Number Number Low Byte (0-255)
Number High Byte (0-255)
N/A
12 Display String String Data N/A
13 PWM Enable Control PWM Channel (1-2)
Enabled (0-1)
N/A
14 PWM Duty Control PWM Channel (1-2)
Duty (0-255)
N/A
15 PWM Period Control Prescaler (0-2) N/A
16 PWM Overcurrent Check N/A Overcurrent State (0-1)
17 EEPROM Write Address (0-255)
Data (0-255)
N/A
18 EEPROM Read Address (0-255) Data (0-255)
19 CAN Set Data Num Bytes (0-8)
Data0 (0-255) Data1 (0-255) Data2 (0-255) Data3 (0-255)
Data4 (0-255) Data5 (0-255) Data6 (0-255) Data7 (0-255)
N/A
20 CAN Send Message ID Low Byte (0-255)
ID High Byte (0-7)
N/A
21 CAN Check Incoming N/A ID High
ID Low
22 CAN Get RX Data N/A Num Bytes (0-8)
23 Register Read Address Low Byte (0-255)
Address High Byte (0-255)
Register Data Byte (0-255)
24 Register Write Address Low Byte (0-255)
Address High Byte (0-255) Register Data Byte (0-255)
N/A
Component Source
The component source code is available here.
FC6 Icon.png MIAC PIC Slave Component
Fc9-comp-macro.png LCDPrintString
Prints a string to the LCD on the MIAC.
Fc9-comp-macro.png GetRegisterValue
Gets the value of the register specified on the MIAC
Fc9-u16-icon.png - UINT RegAddress
Fc9-comp-macro.png GetAnalogueInput
Returns the value for a specific analogue input on the MIAC slave.
Fc9-u8-icon.png - BYTE Input
Fc9-comp-macro.png LCDPrintNumber
Prints out a number to the display on the MIAC.
Fc9-s16-icon.png - INT Number
Fc9-comp-macro.png CANTx
Sends the Tx data with the ID specified in the form of a CAN message
Fc9-u16-icon.png - UINT CANID
Fc9-comp-macro.png GetKeypadBuffer
Returns a keypress from the keypress buffer, returns 255 if no keypress is available.
Fc9-comp-macro.png SetRegisterValue
Sets the value of the register specified on the MIAC
Fc9-u8-icon.png - BYTE Value
Fc9-comp-macro.png PWMSetPeriod
Sets the PWM period for the channel specified
Fc9-u8-icon.png - BYTE Period
Fc9-comp-macro.png PWMOvercurrentCheck
Checks the PWM outputs to see if they are overcurrent
Fc9-comp-macro.png GetEEPROMData
Reads a byte from the EEPROM data memory
Fc9-comp-macro.png PWMControl
Sets the PWM channel specified to be enabled or disabled
Fc9-u8-icon.png - BYTE Enable
Fc9-comp-macro.png CANSetTxData
Sets the LCD cursor position on the MIAC
Fc9-u8-icon.png - BYTE DataCount
Fc9-u8-icon.png - BYTE d0
Fc9-u8-icon.png - BYTE d1
Fc9-u8-icon.png - BYTE d2
Fc9-u8-icon.png - BYTE d3
Fc9-u8-icon.png - BYTE d4
Fc9-u8-icon.png - BYTE d5
Fc9-u8-icon.png - BYTE d6
Fc9-u8-icon.png - BYTE d7
Fc9-comp-macro.png GetDigitalInputs
Returns the value for a all 8 digital inputs on the MIAC slave.
Fc9-comp-macro.png SetEEPROMData
Writes a byte to the EEPROM data memory
Fc9-comp-macro.png CANGetRxData
Collects the data from the last received CAN message
Fc9-comp-macro.png PWMSetDuty
Sets the duty cycle for the PWM channel specified
Fc9-u8-icon.png - BYTE Duty
Fc9-comp-macro.png SetOutputBank
Controls the state of one of the transistor outputs on the MIAC slave.
Fc9-u8-icon.png - BYTE Mask
Fc9-u8-icon.png - BYTE Output_States
Fc9-comp-macro.png SetTransistorOutput
Fc9-u8-icon.png - BYTE Transistor
Fc9-u8-icon.png - BYTE State
Returns the value for a specific digital input on the MIAC slave.
Fc9-comp-macro.png ClearKeypadBuffer
Destroys the contents of the keypad buffer.
Fc9-comp-macro.png LCDSetCursor
Fc9-u8-icon.png - BYTE x
Fc9-u8-icon.png - BYTE y
Fc9-comp-macro.png CANCheckRx
Checks to see if a CAN message has been received, if so the ID is returned
Fc9-comp-macro.png LCDClear
Clears the LCD display on the MIAC.
Fc9-comp-macro.png SetRelayOutput
Controls the state of one of the Relay outputs on the MIAC slave.
Fc9-u8-icon.png - BYTE Relay
Fc9-type-16-icon.png Instance
USB Slave Instance, if empty then is the MIAC slave firmware loaded, Is the MIAC slave driver installed, Is the MIAC connected and powered.
Fc9-conn-icon.png Simulations
