| Author | Matrix Ltd |
| Version | 1.9 |
GLCD (SSD1306) I2C component
Graphical display component based on the I2C version of the SSD1306 monochrome graphical controller IC. Functions without the use of a read pin by hosting the 1K of graphical memory using the  microcontroller's RAM memory.
|   | ReadFontWidth |
|  - BYTE | Font |
|  - BYTE | Character |
|  - BYTE | Return |
|   | SetFontScaler |
|  - BYTE | ScaleX |
|  - BYTE | ScaleY |
|  - VOID | Return |
|   | SendCommand |
|  - BYTE | Command |
|  - VOID | Return |
|   | PrintNumber |
|  - INT | Number |
|  - UINT | X |
|  - UINT | Y |
|  - BYTE | Font |
|  - BYTE | Transparent |
|  - VOID | Return |
|   | DrawLine |
|  - UINT | X1 |
|  - UINT | Y1 |
|  - UINT | X2 |
|  - UINT | Y2 |
|  - VOID | Return |
|   | DrawEllipse |
|  - UINT | X |
|  - UINT | Y |
|  - UINT | XRadius |
|  - UINT | YRadius |
|  - BYTE | Solid |
|  - VOID | Return |
|   | Plot |
|  - UINT | X1 |
|  - UINT | Y1 |
|  - VOID | Return |
|   | ControlDisplay |
| Allows the display to be switched on and off |
|  - BYTE | Control |
| 0=Off, 1=On |
|  - VOID | Return |
|   | SetDisplayOrientation |
|  - BYTE | Orientation |
|  - VOID | Return |
|   | BPlot |
|  - UINT | X1 |
|  - UINT | Y1 |
|  - VOID | Return |
|   | ReadFontStat |
|  - BYTE | Font |
|  - BYTE | Index |
|  - BYTE | Return |
|   | Print |
|  - STRING | Str |
|  - UINT | X1 |
|  - UINT | Y1 |
|  - BYTE | Font |
|  - VOID | Return |
|   | ControlContrast |
| Sets the display contrast from 0 to 255. |
|  - BYTE | Contrast |
| Range 0 - 255, Default 207 |
|  - VOID | Return |
|   | ClearDisplay |
|  - VOID | Return |
|   | SetBackgroundColour |
| Specifies the colour of the background by creating a mixture of red, green and blue. |
|  - BYTE | PixelColour |
| 0=White, 1=Black |
|  - VOID | Return |
|   | DrawCircle |
|  - UINT | X |
|  - UINT | Y |
|  - UINT | Radius |
|  - BYTE | Solid |
|  - VOID | Return |
|   | SetForegroundColour |
| Specifies the colour of the foreground by creating a mixture of red, green and blue. |
| 0=White, 1=Black |
|  - VOID | Return |
|   | DrawRectangle |
|  - UINT | X1 |
|  - UINT | Y1 |
|  - UINT | X2 |
|  - UINT | Y2 |
|  - BYTE | Solid |
|  - VOID | Return |
|   | Initialise |
|  - VOID | Return |
|   | InvertDisplay |
|  - VOID | Return |
|   | Properties |
|   | Pixel Width |
|   | Pixel Height |
|   | Interlaced |
| Determines if the display is interlaced in the Y axis or not |
|   | Offset X |
|   | Offset Y |
|   | Monochrome |
|   | Foreground Color |
|   | Background Color |
|   | Colour Bit Depth |
|   | Red Bit Depth |
|   | Green Bit Depth |
|   | Blue Bit Depth |
|   | Font Count |
|   | Font |
|   | Character Spacing |
|   | Space Width |
|   | Font |
|   | Character Spacing |
|   | Space Width |
|   | Font |
|   | Character Spacing |
|   | Space Width |
|   | Font |
|   | Character Spacing |
|   | Space Width |
|   | Display Method |
| Chooses which method to use when drawing to the gLCD component The bitmap is the more common mode but may run slowly on some machines. The point cloud should run faster but may use more memory. |
|   | Simulate Comms |
| Allows the communications to be simulated to either see the waveforms on the data recorder or to drive an injector component. |
|   | Console Data |
| Selects if the console data is automatically generated or not |
|   | Scope Traces |
| Selects if the component pin connections are automatically generated on the data recorder window or not. Yes: Automatically add the component pins to a group on the data recorder which will reflect the sim data during simultion. No: Do not show the pin signals on the data recorder window. |
|   | API |
| Specifies the injector component on the panel to interact with to provide comms simulation. |
|   | Connections |
|   | I2C Address |
|   | Channel |
| Channel selection |
|   | Baud Select |
| Baud rate option selector |
|   | Baud Rate |
| Baud rate to be used |
|   | Stop Delay |
| On older microcontroller devices there is a potential for the I2C hardware channel to lock up if there is not  a 10ms delay between an I2C stop event and the next I2C start event.  Most modern microcontrollers will not have a problem so this property can be disabled to speed up the  I2C communications. |
|   | SDA |
| Pin used for SDA (data signal) |
|   | SCL |
| Pin used for SCL (clock signal) |
|   | Simulations |
