| Author
Matrix TSL
| Version
1.0
| Category
Mechatronics
Gearbox component
A simple component to couple together two rotating shafts via a gearbox. The gearbox can be used to scale the input rotational speed and optionally reverse the output direction.
Rotate
- FLOAT
Angle
Gear Ratio
| Sets the input to output gear ratio. For example a ratio of 2:1 would be 0.5, a ratio of 1:5 would be 5.0. Negative ratio values allow the input direction to be reversed.
Width
Height
Depth
Input
| Input connection for example a motor or other active component or primitive.
Output
| Output connection for example a primitive or a component such as a linear slide or gearbox.
Input Offset
| Distance along the shaft from the center of the input object to the center of the coupling.
Output Offset
| Distance along the shaft from the center of the coupling to the center of the output object.
Output Translation X
| Distance along the X axis from the center of the coupling to the center of the output object.
Output Translation Y
Simulations
