Component: Bluetooth (ESP32 SPP) (Wireless)
Revision as of 16:20, 22 November 2021 by BenR (talk | contribs) (→Examples)
Category Wireless
Bluetooth (ESP32 SPP) component
Bluetooth slave component designed to run on a ESP32 providing legacy SPP functionality. BT Legacy functionality must be switched on via the sdkconfig file.
A simple example file showing how to send and receive data using the ESP32 Bluetooth Serial Port Profile.
ESP_BT
The SPP legacy bluetooth mode must be enabled in the ESP32 config file to allow SSP to work. For details please see this forum topic.
For problems sending strings or missing data bytes, please see this forum topic.
ReceiveByte
Attempts to receive a byte from the bluetooth serial port. 0-255 = a valid received value 256 = a timeout has occured
- UINT Timeout
Number of ms to wait for incoming data
SendString
Sends a string to the Bluetooth serial connection
- STRING Data
Data Array to send
CheckConnectionStatus
Checks to see if the Bluetooth device is connected. Returns 1 if connected.
- BOOL Return
ReceiveCount
Collects the number of bytes currently stored in the receive buffer.
ReceiveArray
Attempts to receive an array of bytes from the bluetooth serial port. Returns the number of bytes received.
- BYTE Data
Buffer to place received data into
- UINT MaxBytes
Max number of bytes to try and read within the time
- UINT Timeout
SendArray
Sends a byte to the Bluetooth serial connection
- BYTE Data
Data Array to send
- UINT NumBytes
Number of bytes to send
SendByte
- BYTE Data
ReceiveString
- UINT MaxBytes
- UINT Timeout
- STRING Return
Starts up the Bluetooth communications SPP service.
Device Name
Sets the Bluetooth device friendly name
Receive Buffer
Configures the size of the receive buffer in bytes to store incoming data until we are ready to receive it.
Data Receive Interrupt
Verbose Debug
When enabled debug messages will be placed onto UART CH1 which is generally connected to via a Serial to USB IC to pipe messages back to the host PC.
Simulations
COM Port
Selects which port to communicate with, only lists ports which are currently available.
Refresh COM Ports
When set to yes the COM port list is rescanned for newly connected or available ports. Note that refreshing the ports list may take a few seconds depending on the number of connected ports.
Baud
Baud rate passed to the COM port to control the rate of data.
