Component: Switch (Push, Dashboard) ()
| Author | Matrix Ltd |
| Version | 1.1 |
| Category |
Switch (Push, Dashboard) component
Simple momentary push-button using the Matrix dashboard theme.
BASICIO
Switch
(5V / 11K) * 10K = 4.54545V
