Component: GameCode (Misc Circuit)
Jump to navigationJump to search| Author | Jef De Bruyne |
| Category | Misc Circuit |
GameCode component
A small handheld device designed for creating embedded games. Complete with a 8 x 16 LED display, 4-Way DPAD with 4 additional push switches Buzzer, Vibration, MP3 Player, Potentiometer and Lithium battery management. Programmed via USB.
FREE
GSM Example
The AT injector component allows us to simulate the response of the GSM module.
| PwrLedSet | |
| Control the PWR LED. 0 = red + green 1 = red 2 = green | |
| Value | |
| 0 = red + green, 1 = red, 2 = green | |
| EEStoreValue | |
| Saves a value to none volitile memory | |
| Address | |
| Address to write to, Range: 0-255 | |
| Value | |
| Value to store, Range: 0-255 | |
| MP3GetStatus | |
| Returns the status of the MP3 module. 0 = module in sleep 1 = track is playing 2 = track is pauzed 3 = track is stopped | |
| MP3PausePlayResetStop | |
| Allows the current playing track to be paused, restarted or stopped. | |
| Mode | |
| 0=Pause, 1=Play, 2=Reset, 3=Stop | |
| MP3SendCommand | |
| Send commands to MP3 module. Check datasheet for info. | |
| Command | |
| Para1 | |
| Para2 | |
| EEReadValue | |
| Retreives a value from none volitile memory | |
| Address | |
| DisplayWriteNumber | |
| Show a number ranging from 000 to 999 on the display. Number is printed vertically. | |
| Value | |
| Enter a number from 0 to 999. | |
| DisplayClear | |
| Clear the display. | |
| BatteryRead | |
| Read and return the voltage level of the battery in millivolt. | |
| LedsWrite | |
| Set the button-leds. MSB = leftmost led LSB = rightmost led | |
| Value | |
| MSB = leftmost dot, LSB = rightmost dot | |
| MP3SetVolume | |
| Sets the volume level for the MP3 module | |
| Volume | |
| Range: 0 (min) - 30 (max) | |
| DisplayBrightness | |
| Control the brightness of the display. | |
| Value | |
| Enter value from 0 to 15 | |
| Initializes all present hardware and communication. Place this at the very start of your code. | |
| Properties | |
| LED On | |
| LED Off | |
| On Colour | |
| Off Colour | |
| Background Colour | |
| Connections | |
| Simulations | |
