Component: Slider control (Advanced Shapes)
Jump to navigationJump to search| Author | Matrix Ltd |
| Version | 1.1 |
| Category | Advanced Shapes |
Slider control component
A simple graphical interface for a vertical meter or slider control. This can be used within custom components to give them a way to display an analogue value, or to allow setting a value by clicking and dragging with the mouse.
MODELS
Simple example showing how to use the simulation slider component as a meter display for use in monitoring type applications.
 Meters
Meters
|   | GetValue |
| Gets the current value of the slider. This will be within the range set by the SetRange macro. | |
|  - FLOAT | Return |
|   | SetValue |
| Set the current value of the slider. This will override any value set by using the mouse. | |
|  - FLOAT | Value |
| The value to set. | |
|  - VOID | Return |
|   | SetInteractive |
| Set whether the mouse can be used to change the slider value. | |
|  - BOOL | Enable |
| Set true to allow clicks to set scale | |
|  - VOID | Return |
|   | ShowScale |
| Set whether graduated marking are shown along the length of the slider. | |
|  - BOOL | Show |
| True to show scale, else false | |
|  - VOID | Return |
|   | SetRange |
| Set the minimum and maximum values that can be shown on the slider. | |
|  - INT | Min |
| Min (start) value | |
|  - INT | Max |
| Maximum (end) value | |
|  - VOID | Return |
|   | Properties |
|   | Connections |
|   | Simulations |
