| Author
Matrix Ltd
| Version
1.1
| Category
LED (5mm, PCB) component
An industry standard 5mm diameter LED. Any color may be chosen, and the leads trimmed to length.
BASICIO
Show
| Decide what labels to show... None - no labels are displayed Name - shows each component's name Property - shows a particular property of each component (see 'property' below.
Property
| Show a particular property of each object. If a port or pin property is chosen, the label can be abbreviated to remove the '$PORT' text.
Color
| Color of the labels text.
Scale
| Sets the basic size (text height) of the labels.
Follow Zoom
| Whether labels get bigger and smaller when the panel is zoomed in and out.
Position
| Position of the label relative to tehe component
Pin
| Chip pin to connect the LED to.
Polarity
| Active High: Pin true -> On color, Pin false -> Off color Active Low: Pin true -> Off color, Pin false -> On color
Simulations
Color
| The color of the LED when it is turned on.
Trim Leads
| Trim the length of the two leads. Length cannot be less than 3.0, or greater than the length as supplied.
