Component: LED (LES, Panel) ()
Revision as of 15:25, 10 February 2022 by MartinW (talk | contribs) (→Examples)
Version 1.3
Category
LED (LES, Panel) component
Panel lamp for a LES bulb. Colour can be changed in component properties.
BASICIO
LED Resistor Calculator Tool
Show
Decide what labels to show... None - no labels are displayed Name - shows each component's name Property - shows a particular property of each component (see 'property' below.
Property
Show a particular property of each object. If a port or pin property is chosen, the label can be abbreviated to remove the '$PORT' text.
Color
Color of the labels text.
Scale
Sets the basic size (text height) of the labels.
Follow Zoom
Whether labels get bigger and smaller when the panel is zoomed in and out.
Position
Position of the label relative to the component.
Connection
Chip pin to which the LED is connected.
Polarity
Active High: Pin true -> On color, Pin false -> Off color Active Low: Pin true -> Off color, Pin false -> True color
Simulations
Color
The color of the lmap when truned on. When turned off, it will use a much darker shade of the same hue.
