Component: Potentiometer (Trimmer) ()
Revision as of 15:49, 14 February 2022 by MartinW (talk | contribs) (→Examples)
Version 1.4
Category
Potentiometer (Trimmer) component
Trim Pot for 0.1mm pitch PCB. With finger dial knob. Pointer colour can be changed from component properties.
BASICIO
Potentiometer Example
VRef voltage
VRef option
Conversion speed
Acquisition cycles
Bit Depth
Simulations
Start Angle
Sweep Angle
Color
