Component: Potentiometer (Black) ()
Revision as of 15:49, 14 February 2022 by MartinW (talk | contribs) (→Examples)
Version 1.4
Category
Potentiometer (Black) component
Potentiometer with black plastic knob. Pointer colour can be changed in component properties.
BASICIO
Potentiometer Example
VRef voltage
VRef option
Conversion speed
Acquisition cycles
Bit Depth
Simulations
Start Angle
Sweep Angle
Color
Colour of the pointer.
