Component: Switch (Toggle, PCB) ()
Revision as of 15:07, 15 February 2022 by MartinW (talk | contribs) (→Examples)
Version 1.1
Category
Switch (Toggle, PCB) component
Miniature toggle switch with metal tang. Pins for PCB mounting.
BASICIO
Here is an example Flowcode program to read the value of a switch. Switch
(5V / 11K) * 10K = 4.54545V
Connection
Chip pin to which this switch is connected.
Polarity
Sets whether the pin should go high or low when the switch is activated.
Debounce (ms)
Time in milliseconds allowed for the pin to stabilise following a change of state. NB) Debouncing is only used when reading the switch state with the component macros. Chip pin is NOT debounced.
Simulations
Operation
Latching - click the switch to turn it on, click again to turn it off. Momentary - click the switch to turn it on, release the mouse to turn it off.
