Component: 3D Printer (Scenarios)
Revision as of 17:43, 9 November 2022 by Wiki bot (talk | contribs)
Version 1.4
Category Scenarios
3D Printer component
A simulation only version of a very basic 3D printer such as a standard RepRap.
Please click here for the component source code: FC_Comp_Source_3D_Printer.fcfx
3D Print Using Standard 3D Printer CAD file
A simulated 3D print using an external G code file from an actual 3D printer. The G code file must be placed into the same directory as the Flowcode project to work correctly. FC6 Icon.png G-Code_Parser File:Batman.G
3D Maze Generator
A simple 3D maze generator using the 3D printer component to draw the maze. FC6 Icon.png Maze_Builder_3DP Print2.jpg
Fc9-comp-macro.png ClearPrevPrint
Clears all of the content from any previous print cycles.
Fc9-comp-macro.png ControlPrintHead
Controls the print extruder which plots the location of the print head as the head moves. If Enable = 0 then the extruder is disabled If Enable != 0 then the extruder is enabled
Fc9-u8-icon.png - BYTE Enable
Controls if the extruder is active or not
Fc9-comp-macro.png MoveByXYZ
Moves the print head by the amount specified in the axis variables using linear interpolation.
Fc9-s16-icon.png - INT X
Fc9-s16-icon.png - INT Y
Fc9-s16-icon.png - INT Z
Fc9-comp-macro.png SetMovementSpeed
Allows the movement speed to be set progmatically. Range 0 - 100
Fc9-u8-icon.png - BYTE Speed
Speed control (0 - 100)
Fc9-comp-macro.png MoveToHome
Returns the print head to the start position (0,0,0)
Fc9-comp-macro.png MoveToXYZ
Moves the print head to the specific location specified in the axis variables using linear interpolation.
Fc9-u16-icon.png - UINT X
Fc9-u16-icon.png - UINT Y
Fc9-u16-icon.png - UINT Z
Fc9-comp-macro.png MoveByXYZReal
Fc9-f32-icon.png - FLOAT X
Fc9-f32-icon.png - FLOAT Y
Fc9-f32-icon.png - FLOAT Z
Fc9-comp-macro.png SetMovementSpeedReal
Allows the movement speed to be set progmatically. Range 0.0 - 100.0
Fc9-f32-icon.png - FLOAT Speed
Fc9-comp-macro.png MoveToXYZReal
Fc9-comp-macro.png Initialise
Sets up the 3D printer component by homing, clearing old print data and assigning the movement speed.
Fc9-type-1-icon.png Bed Colour
Specifies the colour of the print bed.
Fc9-type-1-icon.png Print Colour
Specifies the colour of the print output.
Fc9-type-14-icon.png Print Speed (0-100)
Specifies the speed of the printer movements. 100 = as fast as possible.
Fc9-type-16-icon.png Print Type
Specifies how the print is drawn. Object based - uses panel primitives to build up the 3D object, useful for simulated interaction e.g. the formula flowcode and the maze solving example. Point cloud based - uses the point cloud interface to allow complex objects to be built without slowing down the panel interface.
Fc9-type-15-icon.png Print Size
Specifies the size of a single print object.
Fc9-type-12-icon.png Print Shape
Specifies the shape of the print object.
Fc9-conn-icon.png Max Print Dimensions
Fc9-type-14-icon.png X Width
Printer dimensions X axis
Fc9-type-14-icon.png Y Length
Printer dimensions Y axis
Fc9-type-14-icon.png Z Height
Printer dimensions Z axis
