Component: DAC Quad (MCP4728) (MCP4728) (Analog Output)
| Category | Analog Output |
DAC Quad (MCP4728) component
Component to drive a quad digital to analogue converter (DAC) IC from Microchip via an I2C interface. Compatible with MCP4728 (12-Bit) devices.
Please click here for the component source code: FC_Comp_Source_DAC_MCP4728.fcfx
| SetOutput | |
| Sets the output voltage of the DAC 12-Bit: Range 0-4095 | |
| Channel | |
| Range: 0-3 / 0=DAC Channel 0 / 1=DAC Channel 1 ... | |
| DAC_Value | |
| The value to output to the DAC | |
| ControlPins | |
| Allows Shutdown (SHDN) and Latch (LDAC) pins to be controlled directly if enabled. | |
| Latch | |
| 0 = Data output driven from DAC register, 1 = Data output locked | |
| Disable | |
| Disables the DAC output. | |
| Channel | |
| Enable | |
| Enables the DAC Output. | |
| Channel | |
| Configures the SPI peripheral ready for communications and initialises the internal variables. DAC needs to be enabled before any output voltage can be generated. | |
