Component: Touch Pads (EBM013) (EBM Modules)
Revision as of 17:46, 9 November 2022 by Wiki bot (talk | contribs)
Category EBM Modules
Touch Pads component
This board provides two touch areas for use with capacitive sensing. Hence two digital touch switches can be implemented. This component directly interfaces with the EBM013 Sensors board.
Please click here for the component source code: FC_Comp_Source_EBM013v5.fcfx
Sample program using the EBM013 - Touch Pads sensor.
Sensors are first calibrated and then can be read as digital switches
FC6 Icon.png EBM013 Example
Fc9-comp-macro.png GetTouchValue
Samples the touch sensor ADC value and returns it Always samples both channels, but only returns the chosen channel
Fc9-bool-icon.png - BOOL Switch
Select Switch. Switch 1 = 0, Switch 2 = 1
Fc9-comp-macro.png GetTouchPressed
Returns non-zero if touch detected
Fc9-u16-icon.png - UINT OffValue
Fc9-u8-icon.png - BYTE Threshold
Provide the threshold value for the pad to be considered touched
Fc9-type-6-icon.png Channel 1
ADC Channel number
Fc9-type-6-icon.png Channel 2
Fc9-conn-icon.png Simulation Properties
Fc9-conn-icon.png Switch 1
Fc9-type-21-icon.png On Value
Fc9-type-21-icon.png Off Value
Fc9-conn-icon.png Switch 2
