Component: Temp / Humidity (SHT21) (Environmental)
| Version | 2.0 |
| Category | Environmental |
Temp / Humidity component
Humidity and temperature sensor using an SHT21 IC connected via I2C. On screen GUI allows temperature and humidity values to be simulated, and will show all I2C communication in a console window.
Please click here for the component source code: FC_Comp_Source_Humidity_SHT21.fcfx
| GetTemperatureReal | |
| Return temperature reading as a float value in degrees C | |
| GetTemperatureData | |
| Returns the raw register pair value | |
| GetTemperatureInt | |
| Return temperature reading as an integer value in degrees C | |
| GetHumidityInt | |
| returns the relative Humidity reading as an integer value | |
| GetHumidityReal | |
| returns the Humidity reading as a float value | |
| GetHumidityData | |
| Initialises the component ready for I2C communications | |
