Component: Injector (DS1307 RTC) ()
Jump to navigationJump to searchAuthor | Matrix Ltd |
Version | 1.1 |
Category |
Injector (DS1307 RTC) component
Comms data injector to allow simulation of a DS1307 Real Time Clock and RAM.
Please click here for the component source code: FC_Comp_Source_InjectorDS1307.fcfx
I2C DS1307 Example
InitialiseInjector |
Sets up the injector ready to receive commands or send data | |
InjectorName |
Name of the console that will be created | |
Return |
RxByteCount |
Returns the number of bytes currently sat in the receive buffer. | |
Return |
TxByte |
Puts a byte onto the comms channel. | |
DataByte |
Return |
RxByte |
Attempt to receive a byte back from the injector 0 - 255 = Valid data 256 = RX timeout no data available | |
Return |
GetConsoleHandle |
Gets the handle to the console allowing data displaying on the panel etc. | |
Return |
ChangeState |
Changes the state for I2C or SPI type comms where the data bytes along are not enough to go on. | |
NewState |
Return |
Properties |
DS1307 Injector Settings |
Circular Buffer Size |
Termination Character |
Device Address |
Day Setting |
Configures how the day of the week is calculated. |
