Component: LTSR Current Transducer (Electrical)
Revision as of 17:48, 9 November 2022 by Wiki bot (talk | contribs)
Author medelec35
Category Electrical
LTSR Current Transducer component
LTSR rage of +/- 6, 15 & 25A current Tranducers
Please click here for the component source code: FC_Comp_Source_LTSR_Current_Transducer.fcfx
Current
- FLOAT Return
Device
VDD
VRef option
VRef voltage
Conversion speed
Acquisition cycles
