Component: SCADA (UART Dummy) (SCADA Slaves)
Revision as of 17:49, 9 November 2022 by Wiki bot (talk | contribs) (Created page with "{| style="width:50%" |- | width="20%" style="color:gray;" | Author | Matrix TSL |- | width="20%" style="color:gray;" | Version | 1.0 |- | width="20%" style="color:gray...")
Category SCADA Slaves
SCADA (UART Dummy) component
Dummy SCADA Slave component to enable injector referencing. Supports: Digital IO / UART See Flowcode Help Wiki for firmware.
Please click here for the component source code: FC_Comp_Source_OLD_API_Slave_UART_Dummy.fcfx
IOGetInputPin
- BYTE Pin
Range: 0-13
- BOOL Return
UARTBaud
- BYTE Rate
UARTCheckRX
UARTInitialise
IOSetOutputPin
- BYTE Pin
Range: 0-13
- BOOL State
Range: 0-1
UARTReceive
UARTSend
- BYTE Data
