Component: One Wire Dummy (Misc)
Revision as of 17:49, 9 November 2022 by Wiki bot (talk | contribs) (Created page with "{| style="width:50%" |- | width="20%" style="color:gray;" | Author | Matrix Ltd |- | width="20%" style="color:gray;" | Version | 1.4 |- | width="20%" style="color:gray...")
Version 1.4
Category Misc
One Wire Dummy component
Low level routines for controlling or interacting with a standard one wire interface.
Please click here for the component source code: FC_Comp_Source_One_Wire_Dummy.fcfx
ReceiveByte
TransmitByte
Transmit a byte to the one wire bus a bit at a time
- BYTE Command
SkipROM
Performs a bus reset and the sends the SkipROM command byte
BusReset
Issue a 'ping' on the bus. If there is at least one sensor on the bus then it will generate a presence pulse. Returns 0 if a presense pulse was detected Returns 1 no device was detected
- BOOL Return
MatchROM
Performs a reset followed by the MatchROM code and then the 8-bit ROM code.
- BYTE FamilyCode
- BYTE SerialNumber
ScanBus
Scans the one wire bus to detect all connected devices. Returns the number of one wire devices found.
GetDeviceCount
GetIDByte
Returns byte ectet of the 64-Bit lasered ROM code, 255 on error
- BYTE Device
Device ID - Range: 0 - NumDevices - 1
- BYTE ByteIndex
Index of the data byte. 0=FamilyCode, 1-6=Serial, 7=CRC
Sets up the 1-Wire output pin ready for communications.
