Component: Piezo Sounder (Audio Output)
Revision as of 17:50, 9 November 2022 by Wiki bot (talk | contribs)
Category Audio Output
Piezo Sounder component
Drives a simple variable frequency piezo sounder in hardware and simulates the sound in simulation. To actually drive a piezo you may have to amplify the signal from the microcontroller using a transistor or MOSFET.
Please click here for the component source code: FC_Comp_Source_PiezoSounder.fcfx
Here is a simple example that will create a siren effect using a piezo sounder. Piezo Siren Depending on your Piezo Sounder you may need to amplify the signal from the microcontroller using a NPN transistor or N channel FET.
BuzzerBeep
Switches the buzzer on and off automatically to allow for a series of beeps
- UINT OnTime
Length of time in ms the buzzer will remain on
- UINT OffTime
Length of time in ms the buzzer will remain off
- BYTE NumberLoops
Number of times to repeat the sequence. Range 1-255
- UINT Frequency
frequency in hz to output to the Piezo sounder
BuzzerOnDelay
Switch the Buzzer on for a fixed amount of time
- UINT Time
Time in milliseconds to keep the buzzer on
- UINT Frequency
Frequency to output in Hz
Output Pin
Pin used to drive the output to the buzzer
