Component: Joystick (Sparkfun Quiic) (Analog Input)
| Category | Analog Input |
Joystick (Sparkfun Quiic) component
An XY sprung joystick with click switch allowing for easy user input control. Connected using I2C bus.
Please click here for the component source code: FC_Comp_Source_Sparkfun_Quiic_Joystick.fcfx
| CheckButton | |
| Checks to see if the button has been pressed since the last read of CheckButton or ReadButton. | |
| ReadAxis | |
| Reads a single axis of the joystick and returns as a signed integer value. | |
| Axis | |
| Range 0-1 Where 0=X, 1=Y | |
| Type | |
| 0 = Signed (-512 to 511), 1 = Unsigned (0 to 1023) | |
| ReadButton | |
| Checks to see if the button is currently pressed | |
| Initialises the I2C bus ready for communications with the module. | |
