Component: TCP/IP Dummy (Raspberry Pi) (Comms: Networking)
Author | Matrix Ltd. |
Version | 1.8 |
Category | Comms: Networking |
TCP/IP Dummy component
TCP/IP sockets component for use with Raspberry Pi. Raspberry Pi Only
Please click here for the component source code: FC_Comp_Source_TCPIP_RPI_Dummy.fcfx
Here is an example of using the TCP/IP component as a means to request data from a remote server on the internet or local network.
Example RPI Client Request Data
Here is an example of using the TCP/IP component as a means to serve data to a client via the internet or local network.
Receive |
Receive data into the data buffer. Returns the number of bytes received | |
Data |
Data byte buffer to receive the data | |
Count |
Maximum number of bytes to read | |
Return |
Send |
Send data | |
Data |
Data byte buffer to send | |
Count |
Number of bytes to send | |
Return |
Listen |
Bind the socket to a port on the local host and set to listen mode. First open a socket on the local device using the Socket function and check that it is successful. | |
Port |
Return |
SocketClose |
Close the socket | |
Return |
AcceptOpen |
Return |
AcceptClose |
Close the accept socket | |
Return |
Initialise |
Return |
Properties |
