Component: Drawing Area (Graphical Color)
Revision as of 17:53, 9 November 2022 by Wiki bot (talk | contribs)
Version 1.6
Category Graphical Color
Drawing Area component
Simulation runtime only graphical display component designed for SCADA operations. Allows easy pixel based displays and support for the GLCD libraries such as bitmap drawer and textfield.
Please click here for the component source code: FC_Comp_Source_glcd_SCADA.fcsx
SetFontScaler
- BYTE ScaleX
- BYTE ScaleY
- INT Number
- UINT X
- UINT Y
- BYTE Font
- BYTE Transparent
DrawLine
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
DrawEllipse
- UINT X
- UINT Y
- UINT XRadius
- UINT YRadius
- BYTE Transparent
- BYTE Solid
Plot
- UINT X1
- UINT Y1
DrawStart
DrawLineFast
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
FastPlot
SetDisplayOrientation
- BYTE Orientation
BPlot
- UINT X1
- UINT Y1
Window
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
Print
- STRING Str
- UINT X1
- UINT Y1
- BYTE Font
- BYTE Transparent
ClearDisplay
SetBackgroundColour
- BYTE Red
Range: 0-255
- BYTE Green
Range: 0-255
- BYTE Blue
Range: 0-255
DrawCircle
- UINT X
- UINT Y
- UINT Radius
- BYTE Transparent
- BYTE Solid
SetForegroundColour
- BYTE Red
Range: 0-255
- BYTE Green
Range: 0-255
- BYTE Blue
Range: 0-255
DrawRectangle
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
- BYTE Transparent
- BYTE Solid
Dimensions
Pixel Height
Pixel Width
Colour
Monochrome
Foreground Color
Background Color
Bit Depth
Colour Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
Fonts
Font Count
Font 0
Font
Character Spacing
Space Width
Simulation Mode
Display Method
