Component: Keypad (Hex 4x4) (Keypad)
Revision as of 17:53, 9 November 2022 by Wiki bot (talk | contribs) (Created page with "{| style="width:50%" |- | width="20%" style="color:gray;" | Author | Matrix Ltd |- | width="20%" style="color:gray;" | Version | 1.0 |- | width="20%" style="color:gray...")
Category Keypad
Keypad (Hex 4x4) component
Preset keypad for entering hexadecimal numbers. Macros 'GetIndex' or 'GetNumber' will return the decimal equivalent of the number pressed, or 255 when no key is pressed. 'GetString' will return the character, including 'ABCDEF'.
Please click here for the component source code: FC_Comp_Source_keypad_hex.fcfx
WaitPressed
Blocking call that waits for one of the keys on the keypad to be pressed. The index of the key that was pressed is passed back to the user.
GetAscii
Gets the ASCII value for the current keypress. If no key is pressed then the macro returns the value 255.
GetString
Gets the ASCII value for the current keypress and returns in the form of a string. If no key pressed then the macro returns a null string.
- STRING Return
GetNumber
Gets the numeric value for the current keypress. If no key pressed then the macro returns the value 255.
GetIndex
Gets the index value for the current keypress. If no key pressed then the macro returns the value 255.
WaitReleased
Blocking call that waits for the keys on the keypad to be released. If no key is pressed then the function will return immediatley.
Output Mode
Port
Style
Button
Colour
Specifies the fill colour of the shape
Colour
Specifies the font colour for the item
Button
Colour
Colour
Button
Colour
Colour
Button
Colour
Colour
Button
Colour
Colour
Button
Colour
Colour
Button
Colour
Colour
Button
Colour
Colour
Button
Colour
Colour
Button
Colour
Colour
Button
Colour
Colour
Button
Colour
Colour
Button
Colour
Colour
Button
Colour
Colour
Button
Colour
Colour
Button
Colour
Colour
