Component: Display Manager (Graphical Library)
Author MatrixTSL
Category Graphical Library
Display Manager component
Please click here for the component source code: FC_Comp_Source_DisplayManager.fcfx
The component can create the follow objects.
  • Type_Line - 2 - A simple straight line.
  • Type_Rectangle - 1 - A simple rectangular box.
Type_RectangeFilled - 5 - A filled rectangular box.
Type_Ellipse - 3 - A simple ellipse or circle.
Type_EllipseFilled - 4 - A filled ellipse or circle.
Type_TextBox - 0 - A text area allowing a line of text to be displayed.
The type can be entered by using the component's public constants. Begin with the Display Manager handle name followed by :: and the list of the public variables will be displayed.
For example... DisplayManager1::Type_TextBox
An example showing the creation of some text areas inside formatted shapes.
Display Manager Example
MoveObject
Moves an existing object to absolute coordinates on the screen.
- UINT ObjectID
- UINT X
- UINT Y
ShiftObject
Shifts an existing object coordinates on the screen relative to the previous coordinates.
- UINT ObjectID
- INT X
- INT Y
DrawObject
Draws a single object onto the display without clearing the display. Doesn't draw a textfield component, this is done using the SetObjectText macro.
- UINT ObjectID
ScaleObject
Changes the width and height of the selected Object
- UINT ObjectID
- UINT Width
- UINT Height
RedrawAll
Redraws all the content from the display manager objects. Doesn't draw textfield components, this is done using the SetObjectText macro.
SetObjectText
Assigns text to a single line text object and draws directly to the display. Blanks the selected area first to ensure nothing from previous text is left behind.
- UINT ObjectID
- STRING Text
- BYTE Font
CreateObject
Define an object on the graphical LCD. Returns the Object ID.
- UINT ObjectType
0=TextBox, 1=Rect, 2=Line, 3=Ellipse, 4=FilledEllipse, 5=FilledRect
- UINT X
X Pixel Coordinate
- UINT Y
Y Pixel Coordinate
- UINT Width
Pixel Width or X Radius
- UINT Height
Pixel Height or Y Radius
GLCD Component
Selects the GLCD component to display all the objects
Max Objects
The total number of objects allowed on the screen. Sets the size of the RAM buffers used to track the various screen elements.
