API Panel.Position.Set
Revision as of 11:54, 16 January 2023 by Wiki bot (talk | contribs)
Set
Sets an objects position based on a component or pre-defined position
- HANDLE Dest
- HANDLE Source
The position or component to read from
- BOOL Return
This copies the entire contents of a position from Source to Dest. Either handle may be a position or component.
The position will be converted from the sources coordinate-space into the destination space when it is assigned. This means one unit in the Source space is equivalent to one unit in the Dest space, regardless of the scale of owning components.
  • Add to a calculation icon:
    result = ::Panel.Position.Set(dest, source)
