Component: API UART Dummy (API Slave Devices)
Revision as of 14:39, 16 January 2023 by Wiki bot (talk | contribs)
Version 2.0
Category API Slave Devices
API UART Dummy component
Connects to an Arduino Mega running the API Firmware allowing the board to become a slave to the Flowcode Embedded simulation or Flowcode App Developer. Supports: Digital IO / ADC / I2C / SPI / UART / PWM See Flowcode Help Wiki for firmware.
Please click here for the component source code: FC_Comp_Source_API_UART_Dummy.fcfx
UARTBaud
- BYTE Channel
- BYTE Rate
UARTCheckRX
- BYTE Channel
UARTInitialise
- BYTE Channel
IOSetOutputPin
- BYTE Pin
Range: 0-53
- BOOL State
Range: 0-1
IOGetInputPin
- BYTE Pin
Range: 0-19
- BOOL Return
UARTReceive
- BYTE Channel
UARTSend
- BYTE Channel
- BYTE Data
