Component: Touch Pads (EBM013) (EBM Modules)
| Category | EBM Modules |
Touch Pads component
This board provides two touch areas for use with capacitive sensing. Hence two digital touch switches can be implemented. This component directly interfaces with the EBM013 Sensors board.
Please click here for the component source code: FC_Comp_Source_EBM013v5.fcfx
Sample program using the EBM013 - Touch Pads sensor.
Sensors are first calibrated and then can be read as digital switches
| GetTouchValue | |
| Samples the touch sensor ADC value and returns it Always samples both channels, but only returns the chosen channel | |
| Switch | |
| Select Switch. Switch 1 = 0, Switch 2 = 1 | |
| Properties | |
| Channel 1 | |
| ADC Channel number | |
| Channel 2 | |
| Simulation Properties | |
| Switch 1 | |
| On Value | |
| Off Value | |
| Switch 2 | |
| On Value | |
| Off Value | |
