Component: ADC (AD7680) (Analog Input)
Version | 1.0 |
Category | Analog Input |
ADC (AD7680) component
16-bit external ADC connected to the microcontroller using SPI.
Please click here for the component source code: FC_Comp_Source_ExternalADC_AD7680.fcfx
Overview
The AD7680 is a 2.5V to 5.5V SPI compatible, successive approximation analogue to digital converter (ADC).
The reference for the AD7680 is taken internally from VDD
Pin reference from the datasheet:
This example reads the voltage on the AD7680 Vin and converts the ADC results into a voltage. For the result to be correct, you must change the Voltage variable to match the supply voltage.
Circuit Diagram
SampleADC |
Reads the ADC and returns the reading as an unsigned 16-bit value. Range: 0-65535 / 0=0V / 65535=VCC | |
Return |
Initialise |
Initialise the SPI bus ready for communications, | |
Return |
