Component: 7Segment (Single) (Segment)
Revision as of 14:41, 16 January 2023 by Wiki bot (talk | contribs) (Created page with "{| style="width:50%" |- | width="20%" style="color:gray;" | Author | Matrix Ltd |- | width="20%" style="color:gray;" | Version | 1.4 |- | width="20%" style="color:gray...")
Version 1.4
Category Segment
7Segment (Single) component
Seven segment display modelled after a standard 14mm high unit. LED colour can be changed in properties.
Please click here for the component source code: FC_Comp_Source_LED_7Seg_Single_2dgi.fcfx
ClearDigit
This funtion clears all the individual segments including the decimal point segment. In simulation this sets the colours to the default BGColor component variable. It's default value is 0xCCCCCC
ShowSegments
Allows the individual segments of the display to be controlled.
- BYTE Segments
8-bit Binary value to set the segments, bit0 = segA, bit1 = segB...
ShowDigit
Creates the supplied digit on the 7 segment display. Macro takes the digit to display and a boolean representing whether to display the decimal point segment or not.
- BYTE Digit
Sets the 7seg display with the appropriate digit supplied
- BYTE DecimalPoint
Determines whether decimal point LED is active (True/False)
Display Type
Set this property to match your hardware device. Common Anode: Pin true -> LED off, Pin false -> LED on Common Cathods: Pin true -> LED on, Pin false -> LED off
Show Seg Labels
Show the identifier lables of the segments overlayed over the component.
Common Pin
When using a single 7-segment display you can keep the common pin active by connecting it to VCC or VSS so no output pin is required. When using multiple 7-seg displays you need the common pin to allow you to multiplex between the displays.
Common Type
The state of the output common pin when the 7-segment display is active. Usually a common cathode display uses a low signal and a common anode uses a high signal. If the common pin is routed via a transistor for power amplification then the signal may need to be reversed.
pin0 (A)
Pin connected to the 'A' degment of the display.
pin1 (B)
Pin connected to the 'B' degment of the display.
pin2 (C)
Pin connected to the 'C' degment of the display.
pin3 (D)
Pin connected to the 'D' degment of the display.
pin4 (E)
Pin connected to the 'E' degment of the display.
pin5 (F)
Pin connected to the 'F' degment of the display.
pin6 (G)
Pin connected to the 'G' degment of the display.
pin7 (DP)
Pin connected to the decimal pointt of the display.
common
Pin connection to the 'common' pin of the display - to allow enable/disable of the whole display.
Colors
LED Color
Color when an LED is turned on. When turned off, will use a much darker shade of the same hue.
Bezel Color
Color of the plastic package housing the LEDs
Label Color
Color of the optional segment name labels.
LED Auto Off Colour
