Component: Digital Potentiometer (MCP44XX) (Analog Output)
Revision as of 14:42, 16 January 2023 by Wiki bot (talk | contribs)
Category Analog Output
Digital Potentiometer (MCP44XX) component
The MCP44XX device range supports 4 digital potentiometers or rheostat outputs. 129 or 257 possible output resistance values for each channel.
Please click here for the component source code: FC_Comp_Source_MCP44xx_Digital_Pot.fcfx
Fc9-comp-macro.png IncrementWiper
Increments a single volatile wiper value
Fc9-u8-icon.png - BYTE Index
Range: 0-3
Fc9-comp-macro.png DecrementWiper
Decrements a single volatile wiper value
Range: 0-3
Fc9-comp-macro.png SetWiper
Sets the value of a single wiper
Range: 0-3
Fc9-u16-icon.png - UINT Value
129 Taps Range: 0-128 / 257 Taps Range: 0-256
Fc9-bool-icon.png - BOOL MemoryType
0=Volatile, 1=Nonvolatile
Fc9-comp-macro.png ReadAddress
Reads a value from one of the registers on the device
Range: 0-15
Fc9-comp-macro.png WriteAddress
Writes a value to one of the registers on the device
Range: 0-15
Range: 0-256
Fc9-comp-macro.png Initialise
Startup the I2C peripheral ready for communications.
Fc9-conn-icon.png I2C Properties
Fc9-type-16-icon.png Channel
Channel selection
Fc9-type-5-icon.png SDA
Fc9-type-5-icon.png SCL
Baud rate to be used
Fc9-conn-icon.png Device Properties
Fc9-type-16-icon.png Number of Taps
Fc9-type-16-icon.png Address Bits
Fc9-conn-icon.png Simulation
