Component: MIAC NXT / ECU (MIAC Module)
Revision as of 14:42, 16 January 2023 by Wiki bot (talk | contribs)
Version 1.1
Category MIAC Module
MIAC NXT / ECU component
Component to drive the MIAC NXT / MIAC ECU range of hardware.
Please click here for the component source code: FC_Comp_Source_MIAC_NXT_Component_Source.fcfx
TransistorOutputState
Allows one of the high speed transistor outputs ( A - F ) to be pulled to GND, Pulled to +V or disabled.
- BYTE Channel
Range: 1 - 6 where 1=A / 2=B / 3=C / 4=D / 5=E / 6=F
- BYTE State
0 = Pull to Ground / 1 = Pull to +V / 2 = DisableOutput
DisplayPrintFormattedNumber
- ULONG Number
Enter the number or variable to print to the display
- BOOL Format
0 = Signed, 1 = Unsigned
DisplayPrintFloat
Prints a formatted floating point number to the display
- FLOAT Number
- BYTE DecimalPoints
Number of decimal points to display
DisplayGetCursorPosition
Gets the current pixel position of the cursor within the coordinate space
- BYTE Axis
0=X, 1=Y
ReadTransistorOutputCurrent
Reads the current for one of the transistor outputs ( A - F ) Returns the current as a floating point number in amps
- BYTE Channel
Range: 1 - 6 - 1=A / 2=B / 3=C / 4=D / 5=E / 6=F
- FLOAT Return
RelayOutputState
Allows one of the relay outputs ( Q1 - Q2 ) to be switched on or off.
- BYTE Channel
Range: 1 - 2 Where 1=Q1 / 2=Q2
- BOOL State
0 = Relay Open Circuit / 1 = Relay Closed Circuit
ReadUSBConnected
Checks to see if there is an active USB cable connected to the MIAC. Returns 1 if there is a USB cable present, otherwise returns 0.
- BOOL Return
InputAnalogByte
Reads one of the input channels ( IN1 - IN8 ) as an analogue value with range 0-255
- BYTE Channel
Range: 1 - 8
ReadKeypad
Directly reads the keypad for any current switch inputs. Returns the keypad switch states as a 9-bit value. Bit0 = TopLeft, Bit1 = TopMiddle, Bit2 = TopRight, Bit3 = CenterLeft, etc..
ReadEEPROM
Read a single byte from the EEPROM.
- UINT Address
DisplayClear
Clears all text from the display
DisplayPixel
Sets or clears a pixel at location X, Y.
- UINT X1
- UINT Y1
- BOOL State
0=Off / 1=On
WriteEEPROM
Write a single byte to a location in the EEPROM.
- UINT Address
- BYTE Data
DisplayClearLine
Clears a single line of text from the display
- BYTE Line
Line to clear. Range 0 to CharacterHeight - 1
DisplayPrintASCII
Prints a single ASCII character to the display
- BYTE Character
Holds an ASCII value e.g. 'A'
TransistorPWMDuty
Sets the PWM duty on the selected channel
- BYTE Channel
Range: 1-4 Where 1=A / 2=B / 3=C / 4=D
- BOOL EnableOrState
1 = Enable / 0 = State
- UINT Duty
Range: 0 - 65535
DisplayPrintString
Prints a string of ASCII characters to the display
- STRING Text
Enter the text or variable to print to the display
Print
- STRING Str
- UINT X1
- UINT Y1
- BYTE Font
- BYTE Transparent
TransistorPWMEnable
Enables or disables PWM on the selected channel
- BYTE Channel
PWM on Enable Pin or State Pin - 1 = Enable / 0 = State
- BOOL OnOrOff
1 = Enabled / 0 = Disabled
DisplayCursor
Moves the current pixel position of the cursor within the coordinate space
- UINT X
Sets the pixel position on the X plane, 0 is the left most pixel
- UINT Y
Sets the pixel position on the Y plane, 0 is the top most pixel
InputDigital
Reads one of the input channels ( IN1 - IN8 ) as a digital value with range 0-1
- BYTE Channel
Range: 1 - 8
- BOOL Return
DisplayPrintNumber
Prints a number to the display as an ASCII string
- INT Number
InputAnalogInt
Reads one of the input channels ( IN1 - IN8 ) as an analogue value with range 0-4095
- BYTE Channel
Range: 1 - 8
Starts up the MIAC IO and display.
Transistor Output PWM Settings
Prescaler Divide
Allows the user to change the number of program cycles per PWM cycle count. Note that all PWM channels based on the same timer will share the same prescaler.
Period Register
Allows the user to change the number of counts for the whole PWM period. Note that all PWM channels based on the same timer will share the same period overflow. PIC/AVR Range: 0 - 255 16-bit PIC Range: 0 - 65535
PWM Timer
Timer associated with PWM to drive the output. Warning - All PWM channels linked to the same timer will share the same period and prescaler settings.
Frequency (Hz)
Display Settings
Foreground Color
Background Color
Font
Character Spacing
Space Width
Pin Connections
CAN (2 x Internal + 1 x External MCP2515)
C1 TX
C1 RX
C2 TX
C2 RX
C3 MOSI
C3 MISO
C3 SCK
C3 CS
C3 INT
C3 RES
LIN
LIN TX
LIN RX
LIN Enable
Bluetooth RN4678
BT TX
BT RX
BT Reset
Wifi ESP12S
Wifi TX
Wifi RX
Wifi Reset
Ethernet W5500
ETH MOSI
ETH MISO
ETH SCK
ETH CS
ETH INT
ETH RES
