API Scope.AddOp
Revision as of 13:15, 14 May 2013 by JonnyW (talk | contribs) (XML import API changes)
<sidebar>API contents</sidebar> Adds an operation to act on the inputs of the stream
Class hierarchy
Scope
AddOp
HANDLE StreamH
A handle to a previously created datascope stream
ULONG FuncOp
An operation to perform on the input
Typical values for this parameter:
Name Description
Op_Bound Bound the current value to the expected range of the input
Op_Scale Divide the current value to the expected range of the input
Op_Xor Exclusive-or with the provided integer argument
Op_AndNot Clear the bits in the provided integer argument
Op_And Isolate only the bits in the provided integer argument
Op_Orr Set the bits in the provided integer argument
Op_Not Invert (ones-compliment) the current input
Op_Add Add the argument to the current input
Op_Sub Subtract the argument from the current input
Op_Mul Multiply the argument by the current input
Op_Div Divide the current input by the argument
Op_Pow Raise the input to the power of the argument
Op_Neg Negate (twos compliment) the current input
Op_Recip Perform the reciprocal on the current input
Op_Sqrt Perform a square root on the current input
Op_Ln Perform a natural logarithm on the current input
Op_Ln2 Perform a base-2 logarithm on the current input
Op_Cos Convert the input to its cosine value (input is in radians)
Op_Sin Convert the input to its sine value (input is in radians)
Op_Tan Convert the input to its tangent value (input is in radians)
Op_Int Convert the input from a float to an integer (using the floor function)
FLOAT Arg
An optional argument that may be used by the FuncOp
BOOL
Returns true if the operation is a success, else false
  • Add to a calculation icon:
    result = ::Scope.AddOp(streamh, ::Scope.Op_Bound, arg)
