Component: Robot Arm v2 (AllCode)
| Category | AllCode |
Robot Arm v2 component
Drives the Matrix Robot Arm v2 hardware via the AllCode API. Allows connections via USB, Bluetooth and WIFI.
Please click here for the component source code: FC_Comp_Source_RA2_ComponentSource.fcsx
| SetWIFIPort | |
| Sets the WIFI port number | |
| Port | |
| Default 1245 | |
| SetCalibrationLengths | |
| Sets the lengths of parameters A and D used as part of the kinematics calculations to get and set the angles using XYZ coordinates | |
| LengthA | |
| LengthD | |
| SetMovementSpeed | |
| Controls the movement speed of the arm and the ramping increment | |
| Speed | |
| Range 0-10000 default 8000 | |
| Increment | |
| Range 0 to 5000, default 50 | |
| GetPLCInputs | |
| Reads the inputs on the secondary grove connector used to connect to outputs from a connected PLC or other external switch. | |
| SetGripper | |
| Sets the new position of the gripper | |
| Position | |
| 0 = Closed, 255 = Fully Open | |
| GetWifiIP | |
| Collects the IP address of the robot arm WIFI connection. | |
| GetColourSensor | |
| Samples and returns the RGB values read by the colour sensor | |
| RGB | |
| Byte Array To Hold the RGB sensor values | |
| SetMotor | |
| Sets the step position of a single motor | |
| Motor | |
| 0=A, 1=B, 2=C | |
| Position | |
| ResetToBoot | |
| Resets the board into bootload mode for reprogramming. Comms port will be closed on calling this macro, | |
| IsMoving | |
| Checks to see if the robot arm or gripper is moving. Returns 0 if the arm is not moving and 1 if the arm is still in transit. | |
| SetAngle | |
| Sets the angle of a single motor | |
| Motor | |
| 0=A, 1=B, 2=C | |
| Angle | |
| Range 0.0 to 359.0 | |
| SetXYZ | |
| Moves the machine so that the end tool is in the specified XYZ position. Returns 1 if the coordinates are within range of the Arm else returns 0. | |
| X | |
| Y | |
| Z | |
| HomeAll | |
| Function to automatically home all motors. Macro blocks until complete. | |
| SetRelay | |
| Allows the vacuum relay to be switched on and off. | |
| State | |
| SetCalibrationRadius | |
| Radius | |
| SetAngles | |
| Sets the angle of all motors | |
| AngleA | |
| AngleB | |
| AngleC | |
| HomeAxis | |
| Function to automatically home a specific motor. Macro blocks until complete. | |
| Axis | |
| 0=A, 1=B, 2=C | |
| GetAngles | |
| Collects the current joint angles of the motors. | |
| Angles | |
| Float Array To Hold the step position return values | |
| DisableMotors | |
| Disables all motors | |
| StoreMotors | |
| Stores the specified step position into an internal none volatile memory location. | |
| PositionIndex | |
| Range: 0 to 40 | |
| PositionA | |
| PositionB | |
| PositionC | |
| SetCanId | |
| Stores the specified CAN ID into an internal none volatile memory location. | |
| ID | |
| GetAPI | |
| Gets the API version number | |
| SetMotors | |
| Sets the step position of all motors | |
| PositionA | |
| PositionB | |
| PositionC | |
| SetCanMode | |
| Configures the CAN mode. | |
| Mode | |
| 0=Disabled, 1=Enabled | |
| GetPosition | |
| Collects the current step positions of the motors. | |
| Positions | |
| UINT Array To Hold the step position return values | |
| StoreCurrentPosition | |
| Stores the current position into an internal none volatile memory location. | |
| PositionIndex | |
| Range: 0 to 40 | |
| GetXYZ | |
| Collects the current XYZ position of the end tool. | |
| XYZ | |
| INT Array To Hold the X, Y and Z return values | |
| SetBluetoothMode | |
| Configures the Bluetooth mode. | |
| Mode | |
