API Scope.GetOutputBlock
<sidebar>API contents</sidebar> Gets a block of the output stream with each input sample operated on, returns number of samples read
HANDLE StreamH
- The stream that is to be read
LONG TimeUS
- The time offset to extract the history from, in microseconds
ULONG TimeStep
- The step in microseconds between each sample extracted
ULONG Samples
- The number of samples to extract - this will expand the array
FLOAT[] Buffer
- The buffer to read the sample data into
Returns the block of the output stream with each input sample operated on, returns number of samples read
- Declare a variable 'result' of type ULONG
- Add to a calculation icon:
result = ::Scope.GetOutputBlock(streamh, timeus, timestep, samples, _arraybuffer)
