| Author
Matrix TSL
| Version
1.0
| Category
Audio Output
WAV Library File component
Allows WAV files to be played or recorded using a file component to provide the data. Complete with buffer to allow for uninterrupted playback when performing other tasks. Playback compatible with analogue outputs such as DAC or PWM. Recording compatible with analogue inputs such as a Microphone.
Please click here for the component source code: FC_Comp_Source_WAV_Player_FAT.fcfx
StartPlayback
| Start playing a WAV file from the SD card. Use the GetNextSample and EndOfFile macros to read out the contents of the file. Use the ProcessBuffer macro to maintain the local buffer. Returns 1 if file found and opened, else returns 0.
- STRING
Filename
| WAV Filename e.g. "Test.wav"
- BYTE
EndOfFile
| A simple check to see if we are at the end of the file. Returns 0 if we and not yet at the end fo the file. Returns 1 if we are at the end of the file.
- BOOL
ProcessBuffer
| When Playing a WAV File - Fills the local data buffer from the SD card. When Recording a WAV File - Writes the local data buffer to the SD card. Must be called often enough to maintain playback or recording. Returns 0 for buffer OK 1 for buffer overrun
- BYTE
StopRecording
PutNextSample
| Writes the value for the next sample and auto increments the file pointer. Ideally this function should be called as part of a timer interrupt at the sample rate. The value written should be collected using an analogue input such as a Mic.
- UINT
Sample
GetNumChannels
| Returns the number of audio channels stored in the WAV file during playback.
- BYTE
StartRecording
| Start recording a WAV file to the SD card. Use the WritetNextSample macro to write the contents of the file. Use the ProcessBuffer macro to maintain the local buffer. Returns 1 if file created and opened, else returns 0.
- STRING
Filename
- BYTE
BitsPerSample
| Number of bits per sample - 8 or 16
- ULONG
SampleRate
| Sample Rate in Hz e.g. 8000 for 8KHz
- BYTE
GetBitsPerSample
| Returns the number of bits per sample during playback.
- BYTE
GetNextSample
| Retreives the value for the next sample and auto increments the file pointer. Ideally this function should be called as part of a timer interrupt at the sample rate. The value returned should be passed onto a means of analogue output e.g. a DAC or PWM.
- UINT
LinkTo
Buffer Size
| The number of RAM bytes to allocate to the WAV buffer. The buffer must be big enough to store enough WAV audio samples to maintain playback or recording when doing other program tasks or performing SD card read/write operations.
Memory Type
