Component: Button helper (Helpers)
Jump to navigationJump to searchAuthor | Matrix Ltd |
Version | 1.1 |
Category | Helpers |
Button helper component
A button overlay that allows any object to behave like a button
Please click here for the component source code: FC_Comp_Source_buttonhelper.fcfx
GetStateFor |
Returns true if the button is depressed, else false | |
Target |
Return |
Clear |
Clears all objects from the lists This leaves no links for the button helper | |
Return |
SetDisabledPos |
Sets the position of the released button | |
PositionHandle |
A handle to the position of the depressed location | |
Return |
SetEnabledPos |
Sets the position of the depressed button | |
PositionHandle |
Return |
SetAxis |
Sets the movement axis as an Axis_... constant | |
Axis |
Movement axis to set to, default 4 | |
Return |
SetDisabledPosFor |
Sets the disabled position for an object | |
Target |
Position |
Return |
GetTarget |
Gets the target handle the property links to | |
Return |
GetState |
Return |
Register |
Adds the object to the list if not already there | |
Target |
Return |
SetLatchingFor |
Sets whether the button is depressed when the mouse is released | |
Target |
Enabled |
Return |
SetMode |
Sets the animation mode for the button | |
Mode |
0=User, 1=Up/Down, 2 = Lever | |
Return |
SetEnabledPosFor |
Sets the enabled position for an object | |
Target |
Position |
Return |
SetPivotPosFor |
Sets the position the lever rotates around for an object | |
Target |
Position |
Return |
SetModeFor |
Target |
The target object, 0 for 'set default' | |
Mode |
Return |
SetMovement |
Sets the movement in units or PI/16 steps for the button | |
Move |
Movement to set to - default is 4 | |
Return |
SetAxisFor |
Target |
Axis |
Return |
SetPivotPos |
Sets the position of the object the lever rotates around | |
PositionHandle |
Return |
SetLatching |
Enabled |
Return |
Unregister |
Removes the object to the list if present | |
Target |
Return |
SetMovementFor |
Target |
Move |
Movement to set to, default 4 | |
Return |
Properties |
Host component |
Lever pivot |
