Component: IO Expander (PCF8574) (PCF8574) (General Input)
Revision as of 16:57, 16 January 2023 by Wiki bot (talk | contribs) (Created page with "{| style="width:50%" |- | width="20%" style="color:gray;" | Author | Matrix TSL |- | width="20%" style="color:gray;" | Version | 1.0 |- | width="20%" style="color:gray...")
Category General Input
IO Expander (PCF8574) component
Provides 8 digital input/output pins arranged into an 8-bit port using a I2C bus connection. Up to eight expanders can be connected to the same I2C peripheral by means of three address pins. Supports the PCF8574 and PCF8574A devices allowing up to 16 expanders to be connected to the same I2C bus ( 8 x PCF8574 + 8 x PCF8574A ).
Please click here for the component source code: FC_Comp_Source_IOEXP_PCF8574.fcfx
ReadPort
Reads the value of the IO pins.
WritePort
Writes a value to the IO pins.
- BYTE Value
Value to write. Range 0-255
I²C Communications
Device Type
External Address
Selects the value of the three address pins for the MCP23S17.
Channel selection
Stop Delay
Baud Select
Baud rate to be used
SDA
SCL
API
