Component: IO Expander (PCF8575) (PCF8575) (General Input)
Revision as of 16:57, 16 January 2023 by Wiki bot (talk | contribs) (Created page with "{| style="width:50%" |- | width="20%" style="color:gray;" | Author | Matrix TSL |- | width="20%" style="color:gray;" | Version | 1.0 |- | width="20%" style="color:gray...")
Category General Input
IO Expander (PCF8575) component
Provides 16 digital input/output pins arranged into 8-bit ports using a I2C bus connection. Up to eight expanders can be connected to the same I2C peripheral by means of three address pins. Supports the PCF8575 device allowing up to 8 expanders to be connected to the same I2C bus.
Please click here for the component source code: FC_Comp_Source_IOEXP_PCF8575.fcfx
Fc9-comp-macro.png ReadPort
Reads the current input value of the I/O pins.
Fc9-comp-macro.png WritePort
Writes an output value to the IO pins
Fc9-u16-icon.png - UINT Value
Value to write. Range 0-65535
Fc9-comp-macro.png Initialise
Fc9-conn-icon.png I²C Communications
Fc9-type-16-icon.png Device Type
Fc9-type-16-icon.png External Address
Selects the value of the three address pins for the MCP23S17.
Fc9-type-16-icon.png Channel
Channel selection
Baud rate to be used
Fc9-type-5-icon.png SDA
Fc9-type-5-icon.png SCL
Fc9-conn-icon.png Simulation
Fc9-type-10-icon.png Label
Fc9-type-16-icon.png API
